540-24
540-24
    GREENLEECOMMUNICATIONS(格林利)
    FISHSTIX KIT LONG
540-24 数据手册
FISHSTIX KIT, LONG (540-24). Fish Stix Kit: 1/4 x 24' (6.4mm x 7.3 m) with bullet & J hook nose tips Cat No: 540-24 UPC No: 783310105060 Description • • • • • • Highly visible green color rods can be easily threaded together and seen when working above ceilings, down walls, or under raised floors 1/4 IN (6.4 mm) diameter fiberglass adds rigidity when connecting multiple sections 200 lbs. (0.9 kN) maximum pulling strength Two different threaded tips accommodate various bundles of wire or cable 540-24 includes one 3 IN (0.9 mm) Glo Stix section for improved tip visibility Optional Whisk Nose Tip isavailable for fishing over obstacles, and can be used to guide extended Glo Stix sidewaysabove ceilings by rotating. Can also be used to fish longerlengths by providing a tip that can be snagged from the opposite direction with another extended Fish or Glo Stix with a hook nose tip Specifications • • • • • • • • • • • • Accessory : 10497 Hook Nose Tip, 10498 Bullet Nose Tip, 11426 Whisk Nose Tip Color : Green Diameter : 1/4 IN (6.400 MM) Includes : "Bullet And ?J"" Hook Nose Tips " Length : 24.000 FT (7.300 M) Minimum Bend Radius : 6-1/2 IN (165.000 MM) Replacement Part : 11583 1/4 IN X 4 FT Fish StixSection, 11584 1/4 IN X 6 FT Fish Stix Section, 12920 3/16 IN X 20 IN Glo Stix Section, 11585 3/16 IN x 3 FT Glo Stix Section, 11427 3/16 IN x 5 FT Glo Stix Section, 12922 5/32 INX 4 FT Glo Stix Section, 89803 5/32 IN X 6 FT Section Length : (3) 6.000 FT (1.800 M), (1) 3.000 FT (0.900 M) And (1) 3.000 FT (0.900 M) Glo Stix Section Sections : 5 Sub Brand : Fish Stix Tensile Strength : 200.000 LB (0.900 KN) MaximumPulling Strength Weight : 1.940 LB (0.900 KG)
540-24 价格&库存
很抱歉,暂时无法提供与“540-24”相匹配的价格&库存,您可以联系我们找货
