5708-C
5708-C
    TEMPOCOMMUNICATIONS
    TESTER-GFI CIRCUIT CALIB
5708-C 数据手册
TESTER-GFI & CIRCUIT CALIB GFCI and Circuit Tester Cat No: 5708-C UPC No: 783310076407 Description • • • • Allows instant testing of GFCI receptacles or GFCI circuit breaker protected circuits Checks 120VAC grounded outlets for correct/incorrect wiring LED indicators signal correct wiring, open ground, open neutral, open hot, hot/ground reversed and hot/neutral reversed Lifetime Limited Warranty Specifications • • • • • • • • Accuracy : Current: 10 PCT At Nominal Voltage, Time: Approximately 12 PCT Capacity : 120 VAC, 3-Wire System Cord Length : 16.000 IN (406.000 MM) Dimensions : 5-3/8 IN (137.000 MM) X 2-5/8IN (67.000 MM) X 1-3/4 IN (44.000 MM) Measurement Category : CAT II, 150 V Model : 5708-C Time : ƕ 4 S Interval Between MILAMPTest Impulses ƕ 200 MS Pulse Duration Weight : 0.500 LB (227.000 GM)
5708-C 价格&库存
很抱歉,暂时无法提供与“5708-C”相匹配的价格&库存,您可以联系我们找货
