920XC-20M PC FC
920XC-20M PC FC
    GREENLEECOMMUNICATIONS(格林利)
    OTDR FC CONNECTORS
920XC-20M PC FC 数据手册
HANDHELD MULTI-MODE OTDR 920XC-20M MADE FOR THE TRADE!™ 1 920XC-20M Handheld Multi-Mode OTDR 2 3 Cable Acceptance Testing and Fault Locating Greenlee’s 920XC-20M is a handheld, full-featured OTDR for cable acceptance testing and fault locating. The Autotest function automatically chooses the optimal measurement settings, scans the fiber under test and performs fiber analysis displaying length of fiber and the loss of each event in an easy-to-read table. Also available is the graphical user interface to navigate the trace signature for more detailed views of specific fiber events. 4 5 The 920XC-20M OTDR is indispensable and the ideal tool that all premise technicians and LAN/WAN contractors need in their toolbox. The 920XC-20M series handheld OTDR is designed for enhanced user convenience with its large color LCD display and graphical user interface. The user can activate the measurements function easily by the press of one button. 1. Protective rubber boot Features 2. Menu Functions • • • • • 3. Large color LCD display • • • • • • Economical Compact handheld design Easy to use Fast automated testing 22dB (1300nm), 18dB (850nm) dynamic range 50/125um and 62.5/125um fiber Large backlit LCD display Measure length and defects of coiled fiber Fiber analysis software for data management and report generation RS-232/USB interface NiMH batteries for 8 hours of continuous use for settings and trace store /recall. 4. Run/Stop button to automatically choose settings and run OTDR test. 5. Sealed membrane panel 7 8 6 6. DC charger port 7. USB port for data transfer. 8. OTDR port with dust cover. www.greenlee.com OTDR Operation Modes OTDR Cable Acceptance Report Generation Instrument Setup • Auto mode selects optimal distance range and pulsewidth • All settings are selected through easy to use menu selections • Color and high intensity monochrome settings for bright sunlight conditions • Complete control of fiber analysis settings for auto measurement of splice and end of fiber OTDR Trace Viewer • View and measure all trace files stored on the 920XC-20M • Bellcore Standard OTDR Report (SOR) file storage format • Display trace, fiber events and measurement information on single screen • Display measurement settings used to acquire trace Cable Acceptance Report • Generate professional OTDR cable acceptance reports • Cable acceptance report can be customized by user • Trace signature and fiber events are printed on each report Specifications MODEL OTDR Trace • View and measure test results • One button measurement of all distance and loss information Event View Mode – user can page through each loss event for location in (meters/miles and feet) and loss in dB Manual Measurement Mode – user can perform manual measurement with A and B cursor for distance, loss and reflectance measurements Measurement Setup – user can view settings used to acquire measurement Fiber Analysis Software – user can view settings used for auto measurement of events Wavelength (± 20nm) Dynamic Range (dB) Event Deadzone (m) Attenuation Deadzone (m) Emitter Type Pulsewidth Selectable Ranges (km) Average Time Distance Measurement Accuracy Connector Type FIBER ANALYSIS SOFTWARE Reflection Detect Accuracy Attenuation Detect Accuracy Measurement Data Storage Data Transmission GENERAL Power Supply Battery Life Operating Temperature Storage Temperature Relative Humidity Weight Dimensions 920XC-20M 850 18 1300 22 7 20 LED 12/30/100/275/1us 30/100/275/1us/2us 0.1/0.3/0.5/1.3/2.5/5/10 0.1/0.3/0.5/1.3/2.5/5/10/20/40/80 15s/30s/1 min/2 min/3 min ±(1m + 5 X 105 x distance + sampling space) PC (interchangeable FC, SC, ST) ±4 dB ±0.05 dB/dB 1,000 test curves RS-232/USB port NiMH chargeable battery/AC adapter Support over 8 hours operating on one charge or over 20 hours standby -10° to 50° C -20° to 60° C 0 to 95% (non-condensing) 1.9 lbs. (0.87 kg) 7.7" H x 3.9" W x 2.4" L (196mm x 100mm x 64mm) MADE FOR THE TRADE!™ Ordering Information CAT NUMBER = Replacement Part = Accessory UPC NUMBER DESCRIPTION QTY 920XC-20M UPC FC 25688 Handheld OTDR, 850/1300nm, FC/UPC 1 920XC-20M UPC SC 25689 Handheld OTDR, 850/1300nm, SC/UPC 1 920XC-20M UPC ST 25690 Handheld OTDR, 850/1300nm, ST/UPC 1 AC-ADPT-20-UNI 25691 Universal Power Supply 1 AC-CONN-FC-L2 20996 FC Connector (For UPC & APC) 1 AC-CONN-SC-L2 20998 SC Connector (For UPC & APC) 1 AC-CONN-ST-L2 20997 ST Connector (For UPC Only) 1 1155-0526 10582 Vehicle Adapter (6FT, 5.5 OD, 2.1M) 1 20988 20988 Soft Carry Case 1 20989 20989 USB Cable For OTDR 1 20990 20990 RS-232 Cable 1 20999 20999 NiMH Battery (9.6V) 1 25693 25693 Serial Cable to USB 1 920XC-QR 25692 920XC Quick Reference Guide 1 946 60571 Cleaning Wand (10/PK) 1 948 60692 ReelCleaner™ Connector Cleaning System 1 26307 Single and Multi-Mode OTDR Kit 1 Multi-Mode OTDR Accessories Multi-Mode/Single Mode OTDR Kit 920XC-SM-MM CONTENTS OF EACH MODEL NUMBER Instrument including rechargeable battery, OTDR Trace Viewer software, installation disk, Data transfer cable, AC adapter, protective cover, carrying case, warranty card, CE/ FCC certificate, certificate of calibration. Default language is English and Spanish. Alternate languages of Russian, Portuguese, and German available upon request. www.greenlee.com • MA-5535 07/10 4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070 ©2010 Greenlee Textron Inc. • Printed in USA Greenlee Textron Inc. is a subsidiary of Textron Inc.
920XC-20M PC FC 价格&库存
很抱歉,暂时无法提供与“920XC-20M PC FC”相匹配的价格&库存,您可以联系我们找货
