PA3594
PA3594
    GREENLEECOMMUNICATIONS(格林利)
    PDT SUREPUNCH PRO
PA3594 数据手册
PDT SUREPUNCH-PRO BIX-BLADE CLAMSHELL SurePunch Pro PDT with BIX cut-only (scissors type) blade Cat No: PA3594 UPC No: 769328110395 Description • • • • • • • • • Terminate cable in single punch - including 23 AWG Cat6 Detachable light with long-life LED specially designed to focus the light on the panelwork area Luminous intesity of the LED is 2200 mcd Finger grips and non-slip rubber-embedded cushioned handle for comfort Multi-use spudger that canbe used as a screwdriver or an IDC contact insertion tool Hook to feed wires throughholes Pick to separate bonded twisted-pair cables or to strip insulation and cut wire Adjustable HI/LO spring compression for all cable types.LO= 27.5 lbs (122 N), HI= 37.5 lbs (167 N) Uses twist-and-lock style blades10~ Blade storage area in endof handle with comfortable latch cover Specifications • • Includes : BIX Cut-Only (Scissors Type) Blade Sub Brand : SurePunch Pro
PA3594 价格&库存
很抱歉,暂时无法提供与“PA3594”相匹配的价格&库存,您可以联系我们找货
