215
215
    PANAVISE
215 数据手册
8 5 6 7 4 2 3 1 REVISIONS ZONE REV. DESCRIPTION PR1 INITIAL RELEASE OF PRODUCT SPECIFICATIONS DRAWN/DATE IM APPROVED/DATE 10/04/2017 PIVOT 210° ROTATION 360° D D SPECIFICATIONS OVERALL HEIGHT: ........6.0 [152.40] ROTATION: ....................360 DEGREES SWIVEL: .........................360 DEGREES PIVOT: ...........................210 DEGREES SHIPPING WEIGHT: .......0.28 POUNDS [.13KG] VISE OPENING: ............4 1/2 [114.30] MAXIMUM JAW HEIGHT: ................4 1/8 [104.78] C JAW OPENING 0[0] MIN 4 1/2 [114.30] MAX 3 1 104.78 4 1/8 B C MATERIAL 1. VISE ARM PAIR ASSY: ALUMINUM #380 DIE CAST 2. CROSS BAR: ZINC-PLATED STEEL 3. STANDOFFS: SILICONE RUBBER, BLACK, SHORE 80±5 4. BALL: PA6+30%GF-BLACK 2 151.38 5.96 B 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL 1/64 ANGULAR: MACH 1/2 BEND 1 TWO PLACE DECIMAL 01 THREE PLACE DECIMAL .005 A 152.40 6.00 8 7 6 5 DATE IM 100417 CHECKED 7540 Colbert Drive, Reno, Nevada 89511-1225 Phone (775) 850-2900 Fax (775) 850-2929 TITLE: ENG APPR. MFG APPR. Q.A. INTERPRET GEOMETRIC TOLERANCING PER: ASME 14.5M -2009 COMMENTS: MATERIAL PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF PANAVISE PRODUCTS INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF PANAVISE PRODUCTS INC IS PROHIBITED. DRAWN NAME USED ON NEXT ASSY APPLICATION 4 SIZE DWG. NO. B FINISH REV A 215 SP SHEET 1 OF 1 SCALE: 1:2 WEIGHT: DO NOT SCALE DRAWING 3 MODEL 215 SPEC SHEET 2 1 A
很抱歉,暂时无法提供与“215”相匹配的价格&库存,您可以联系我们找货
