217
217
    PANAVISE
217 数据手册
8 5 6 7 4 2 3 1 REVISIONS ZONE PIVOT 210° REV. DESCRIPTION PR1 INITIAL RELEASE OF PRODUCT SPECIFICATIONS DRAWN/DATE IM APPROVED/DATE 10/04/2017 D D ROTATION 360° SPECIFICATIONS OVERALL HEIGHT: ........9 1/4 [235.00] ROTATION: ....................360 DEGREES SWIVEL: .........................360 DEGREES PIVOT: ...........................210 DEGREES SHIPPING WEIGHT: .......0.6 POUNDS [.27KG] VISE OPENING: ............4 1/2 [114.30] MAXIMUM JAW HEIGHT: ................4 1/8 [104.78] JAW OPENING 0[0] MIN 4 1/2 [114.30] MAX C MATERIAL 1. VISE ARM PAIR ASSY: ALUMINUM #380 DIE CAST 2. 5/8" ADAPTER SHAFT: 6061-T6 ALUMINUM - CLEAR ANODIZE 3. BALL JOINT KNUCKLES: #3 ZINC DIE CAST SILVER PAINT 4. KNOB: KNUCKLE ASSEMBLY ZINC DIE CAST PAINTED BLACK 1/4-28 X 7/8 STEEL SOCKET SCREW BLACK OXIDE 5. CROSS BAR: ZINC-PLATED STEEL 6. STANDOFFS: SILICONE RUBBER, BLACK, SHORE 80±5 7. BALL: PA6+30%GF-BLACK 6 104.78 4 1/8 151.41 5.96 1 C 5 B B 235.00 9 1/4 4 7 126.40 4.98 3 2 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL 1/64 ANGULAR: MACH 1/2 BEND 1 TWO PLACE DECIMAL 01 THREE PLACE DECIMAL .005 A 8 THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF PANAVISE PRODUCTS INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF PANAVISE PRODUCTS INC IS PROHIBITED. 7 6 5 DATE IM 100417 CHECKED 7540 Colbert Drive, Reno, Nevada 89511-1225 Phone (775) 850-2900 Fax (775) 850-2929 TITLE: ENG APPR. MFG APPR. Q.A. INTERPRET GEOMETRIC TOLERANCING PER: ASME 14.5M -2009 COMMENTS: MATERIAL PROPRIETARY AND CONFIDENTIAL 5/8" SHAFT FOR USE IN 300 SERIES BASE DRAWN NAME USED ON NEXT ASSY APPLICATION 4 SIZE DWG. NO. B FINISH REV 217 SP PR1 SHEET 1 OF 1 SCALE: 1:2 WEIGHT: DO NOT SCALE DRAWING 3 MODEL 217 SPEC SHEET 2 1 A
很抱歉,暂时无法提供与“217”相匹配的价格&库存,您可以联系我们找货
