32001
32001
    PARALLAXINC.
    试验板套件 Propeller Tool BlocklyProp 元器件
32001 数据手册
      Inventing Mechanical Add‐on Kit  Product ID: 32001    Overview  The Mechanical Add‐On Kit provides provides the pieces to convert the Inventing  Electronics Base Kit into a rolling robot or motion‐inspired inventions for the Henry Ford  Invention Convention Worldwide. The desired outcomes of the Inventing Kit Series are  inspiration, inventive ability (with electronics, sensors, motors), and self‐confidence;  Parallax provides examples while students bring ideas, identify problems, and create  real‐world solutions in their inventions.     A simple rolling robot can be built around a chassis using cardboard, foam‐core board or  from 3D printing. Even easier, the servos can be attached to the breadboard bottom  using double‐sided sticky‐tape, or consider converting the box to a robot. The tail wheel  is mounted with the aluminum brackets. The confidence and creativity gained by a  classroom of unique robots may be even more impactful than building from a kit with  instructions!  With a bit of student‐added creativity and craft supplies, the continuous rotation servo  motors and other kit hardware can be used to raise or lower things, automate a process  requiring repetitive motion, or make a working physical animation for holidays.            The programming environment for the Invention Kit Series is BlocklyProp. BlocklyProp is  a well‐documented visual programming language based on Google’s open‐source  Blockly. After using the Electronics Base Kit with the Mechanical Add‐On Kit students will  have the ability to envision new solutions using a wide variety of sensors and devices  supported in BlocklyProp simply by looking at the BlocklyProp Reference.      Features     Servos, wheels and tail wheel for robot drivetrain or student‐created inventions  Mounting hardware: screws, nuts, aluminum brackets  PowerPal Module provides for several voltage levels needed for motors or sensors from  battery pack (in the Electronics Base Kit)  Application Ideas      Rotate a camera, sensor, or holiday animation  Customize a simple rolling robot to make an invention prototype  — robotic line painter,  cat exerciser, etc.  Combine with Security Add‐On Kit to make radar‐like distance detection devices  Combine Environmental Add‐On Kit to create mobile environmental measurement  inventions — solar trackers, or robotic farming working models  Details  Kit Contents                 (1) PowerPal Module (#32133)  (1) Standard Servo (#900‐00005)  (2) CR Servo (#900‐00008)      (2) ActivityBot Wheel (#721‐00021)  (2) O‐ring tire (#710‐00200)  (2) Tail Wheel Ball 1" (#700‐00009)  (6) Universal Straight brackets (#720‐00012)  (6) Universal L brackets (#720‐00011)  (1) Small Robot Hardware Pack (#570‐00001)  (1) Cotter pin (#700‐00023)  (1) Parallax screwdriver (#700‐00064)  (1) Parallax Combination Wrench (#700‐10025)  (1) Battery Holder, 5AA (#753‐00007)  (5) 10 k‐ohm resistor (#150‐01030)  (4) 3‐pin straight header (#451‐00303)  Parts and quantities subject to change without notice. Servos require 5AA batteries, not  included.          https://www.parallax.com/product/32001/11‐21‐19
32001 价格&库存
很抱歉,暂时无法提供与“32001”相匹配的价格&库存,您可以联系我们找货
    库存:5
