32003
32003
    PARALLAXINC.
    试验板套件 Propeller Tool BlocklyProp 元器件
32003 数据手册
        Inventing Environmental Add‐on Kit  Product ID: 32003     Overview  The Environmental Add‐On Kit provides students with the components to shape electronic  solutions for real‐world environmental problems. This kit requires the Electronics Base Kit and  is ideal for Henry Ford Invention Convention participants in the grades 6‐8 and 9‐12 categories.  Invention themes around the Environmental Add‐On Kit are plants and farming, environmental  conditions (water, air, soil) and color (of fruit, recyclables). The types of sensors in this kit  measure these parameters while 96x64 color OLED display is included to show the values (as  text and values, bargraphs).  This kit maybe combined with the Mechanical Add‐On Kit to provide motion‐control for  environmental inventions. For example, light levels, temperature, and soil moisture conditions  may be modified by changing the localized environment in a mini greenhouse by adjusting air  flow or watering.     The programming environment for the Invention Kit Series is BlocklyProp. BlocklyProp is a well‐ documented visual programming language based on Google’s open‐source Blockly. After using  the Electronics Base Kit with the Mechanical Add‐On Kit students will have the ability to  envision new solutions using a wide variety of sensors and devices supported in BlocklyProp  simply by looking at the BlocklyProp Reference.      Features      Moisture and liquid level sensors for insertion directly into potted plants, soil, or wet environments  UV light and color sensors for characterizing the physical attributes of what we see  Temperature & humidity sensor for characterizing physical attributes we don't see!  Color OLED display for displaying the data to humans  Application Ideas     Create an optimal micro‐farming system with hydroponics or soil  Measure UV light, temperature and humidity to create a smart‐watering system  Characterize recyclables, fruit or plants by color to automate a process  Details  Kit Contents            (1) Moisture Sensor Probe (#28092)  (1) UV Light Sensor (#28091)  (1) Mini Liquid level Sensor (#28090)  (1) ColorPal Color Sensor (#28380)  (1) CM2302 Temp/Humidity (#28059)  (1) OLED Display (#28087)  (2) MCP3002 A/D Converter (#603‐00039)  (4) 3‐pin Headers (#451‐00303)  (4) Extension cables, 16" (#800‐00160)  (1) Ribbon Cable FM 200 mm (#800‐00064)  Note: Parts and quantities subject to change without notice. For use with the Inventing  Electronics Base Kit (#32000) not included.        https://www.parallax.com/product/32003/11‐21‐19
32003 价格&库存
很抱歉,暂时无法提供与“32003”相匹配的价格&库存,您可以联系我们找货
    库存:1
    32003
    • 1+850.008391+110.48037
    库存:1
