752-00017
752-00017
    PARALLAXINC.
    BATTERY LITHIUM 5.3AH RECHARGBL
752-00017 数据手册
      Gens Ace 5300 mAh LiPo Battery with EC3 Connector Product ID: 752‐00017  This Gens Ace 5300 mAh, 30C, 3S LiPo battery has been customized for easy use with  our ELEV‐8 quadcopters, and provides a longer flight time compared to our 3300 mAh  LiPo battery.  To charge the battery you will need a Lithium Polymer Balance Charger capable of  charging a 3 cell (11.1 volt) battery, and an approved container. We recommend the 3A  LiPo Balance Charger + EC3 Cable and a LiPo Battery Bag ‐ Small (#752‐00015).  Features      159 amp continuous output supports ELEV‐8 quadcopter flight and other high‐power  projects  Customized with a pre‐soldered EC3 Female connector  Balance charging cable with JST‐XHR connector can also attach to a low‐voltage alarm  12 AWG power cable with durable silicon insulation      SHIPPING: Lithium batteries are shipped via UPS only; restrictions apply by country; see details.  WARNING: Lithium Polymer (LiPo) batteries are volatile. Failure to read and follow the  all safety instructions and warnings may result in fire, personal injury and damage to  property if charged or used improperly.  DISCLAIMER OF LIABILITY: Parallax Inc. is not responsible for any direct, indirect,  special, or consequential damages and personal injuries, including that to life, and  health, resulting from the customer’s application and use of these Parallax Inc. products.  You, the customer, assume full and unlimited responsibility for all customer Battery  Pack applications and uses. Your purchase of this product constitutes your agreement to  hereafter assume full and total responsibility for your subsequent utilization of the  Battery Pack and you agree to defend, protect, save harmless, and indemnify Parallax  Inc., its officers, and employees relative to your potential use and misuse of this  product.  Details                Chemistry: Lithium‐ion polymer  Voltage: 11.1 V  Capacity: 5300 mAh  Cell Count: 3  Wire gauge: 12 AWG  Connector type: EC3 female  Nominal Cell Voltage: 3.7 Volts (3.0 V minimum, 4.2 V maximum)  Maximum Continuous Discharge Rate: 30C (159 A)  Maximum Burst Discharge Rate: 50C (318 A)  Maximum Charge Rate: 1C (5.3 A)  Battery Weight: 14.4 oz (408 g)  Dimensions: 1.65 x 5.39 x 1.26 in (42 x 137 x 32 mm)  Operating Temperature, charge: 32 to 113 °F (0 to 45 °C)  Operating Temperature, discharge, 32 to 140 °F (0 to 60 °C)            Downloads & Documentation  3A LiPo Balance Charger Manual ‐ 673.79 KB | updated: 06 Jul 2016 ‐ 3:05 pm  https://www.parallax.com/sites/default/files/downloads/752‐00018‐SKYRC‐e4‐Manual‐v1.0.pdf  Tenergy Balance Charging LiPo Batteries ‐ 337.85 KB | updated: 11 Feb 2016 ‐ 1:0  https://www.parallax.com/sites/default/files/downloads/752‐00009‐Tenergy‐Balance‐Charging‐LiPo‐v1.0.pdf  Lithium‐Ion Polymer Safety Instructions ‐ 92.73 KB | updated: 31 Jul 2014 ‐ 3:43 pm  https://www.parallax.com/sites/default/files/downloads/752‐00010‐Lithium‐Ion‐Polymer‐Battery‐Safety‐V1.pdf        https://www.parallax.com/product/752‐00017 1026‐18
752-00017 价格&库存
很抱歉,暂时无法提供与“752-00017”相匹配的价格&库存,您可以联系我们找货
