DK-ITO-50-1524-10
DK-ITO-50-1524-10
    PARKERCHOMERICS
    RF EMI 屏蔽板 TECKFILM™ 聚酯 15.000"(381.00mm) X 23.976"(609.00mm) X 0.005"(0.13mm)
DK-ITO-50-1524-10 数据手册
TECKFILM™ EMI Shielded Conductive Film Customer Value Proposition: TECKFILM is a highly conductive optical quality polyester film used in display applications requiring EMI shielding and transparency. TECKFILM is an excellent choice for EMI shielding of displays or retrofitting of existing displays. Available in both 14 and 50 ohm/sq, the appropriate level of shielding can be easily implemented. It has a low profile 0.005” (0.127 mm) thick design which allows it to be a suitable solution where mechanical modifications of the application cannot be implemented. The film is coated with a conductive layer on one side that is designed for shielding, grounding, and static discharge applications. TECKFILM is ideal for use on visual displays in instrumentation equipment, LCDs, touchscreens, membrane switches, control panels, computer processing equipment, printers, peripheral equipment, ruggedized equipment, industrial equipment, commercial equipment and large displays. TECKFILM can be die cut to any size, and is available in standard 15 x 24” (381mm x 609 mm) sheets or in 30” (762 mm) wide rolls cut to length. Gasketing can also be provided attached to diecut parts. Contact Information: Parker Hannifin Corporation Chomerics Division 77 Dragon Court Woburn, MA 01801 phone 781 935 4850 fax 781 933 4318 chomailbox@parker.com www.parker.com/chomerics Product Features: Typical Applications: • • • • • • • EMI shielding for displays High light transmission Two shielding levels 14 and 50 ohm/sq Thin sheet material Available in custom die cut parts 30” (762 mm) roll form (14 ohm/sq) 24” (610 mm) roll form (50 ohm/sq) • 15 x 24” (381mm x 609 mm) • • • • • • • • • • • • • standard sheet size Thickness 0.005” +/- 10% (0.127mm) Ideal for moderate EMI shielding Can be retrofit into existing displays Available with optical grade PSA backside only as a custom option Military electronics Tempest environments EMI shielding for touchscreens Shielded cabinets and racks Rugged LCDs Instrument panels Digital signage Industrial displays Medical displays Product Information Typical Termination Options: Specifications Material Heat Stabilized Polyester Surface Finishes Side 1 - Plain Side 2 Option A - Conductive Surface (14 ohms/sq) Side 2 Option B - Conductive Surface (50 ohms/sq) Thickness 0.005” (0.127 mm) +/- 10% Maximum Size 14 ohm/sq - 30” (762 mm) wide roll by 100’ (30.48 m) 50 ohm/sq - 24” (610 mm) wide roll by 100’ (30.48 m) Shielding Effectiveness @ 300 MHz 14 ohm/sq - 31 dB 50 ohm/sq - 18 dB Light Transmission @ 550 nm 14 ohm/sq - 75% 50 ohm/sq - 85% Temperature Range -45°C to +100°C (-49°F to +212°F) Humidity 90% @ 60°C for 2 hrs. - No Effect Color Clear (light gold tint) Order Part # (15” x 24”) 14 ohm/sq sheet - ITO-15-1524-10 50 ohm/sq sheet - ITO-50-1524-10 Shielding Effecvness #1 Direct Contact of Conductive Surface to Housing/Bezel #2 Double-Sided CHO-FOIL Adhesive Around the Perimeter of the Conductive Surface #3 Single or Double-Sided CHO-FOIL “Overhang” with Release Liner #4 Parker Chomerics Gasket (Gasketing with wires is not recommended) 80 14 ohm/sq 50 ohm/sq 70 Shielding Effecveness (dB) 60 50 40 30 20 10 IEEE 299 Open Reference 0 30 300 3000 Frequency (MHz) Light Transmission Conductive Films TECKFILM CHO-FOIL Housing/Bezel Gasket 100 90 50 ohm 80 Transmission (%) 70 14 ohm 60 50 40 30 20 10 0 400 450 500 550 Wavelength (nm) 600 650 700 www.parker.com/chomerics CHOMERICS® is a registered trademark of Parker Hannifin Corporation. TECHFILM™ is a trademark of Parker Hannifin Corporation. TB1088 EN 10/19 © 2017 Parker Hannifin Corporation. All rights reserved. ENGINEERING YOUR SUCCESS.
DK-ITO-50-1524-10 价格&库存
很抱歉,暂时无法提供与“DK-ITO-50-1524-10”相匹配的价格&库存,您可以联系我们找货
