ARGNKIT
ARGNKIT
    PARTICLE
    - nRF52840 收发器; 802.11 b/g/n(Wi-Fi,WiFi,WLAN),Bluetooth® 5 2.4GHz 评估板
ARGNKIT 数据手册
    Argon Kit The Argon is a powerful Wi-Fi enabled development kit that can act as either a standalone Wi-Fi endpoint or Wi-Fi enabled gateway for Particle Mesh networks. It is based on the Nordic nRF52840 and has built-in battery charging circuitry so it’s easy to connect a Li-Po and deploy your local network in minutes. The Argon is great for connecting existing projects to the Particle Device Cloud or as a gateway to connect an entire group of local endpoints. All Particle Hardware is designed from the ground up to work with the Device Cloud; a powerful set of tools and infrastructure to build, connect, and manage your IoT fleet. The Device Cloud for Particle Mesh will be priced by network. All Particle customers get 10 free micro networks using a Wi-Fi or Ethernet gateway. A micro network is defined as a network with 10 total devices and a single gateway. More pricing details to be released soon. In the meantime, check out our documentation. o Contents: o Argon dev board o Mini breadboard o 2.4GHz flex antenna o USB cable o Starter project includes two resistors (220 ohm), one red LED, and one photodiode   o Specs: o Espressif ESP32‐D0WD 2.4G Wi‐Fi coprocessor ‐ On‐board 4MB flash for ESP32 ‐ 802.11 b/g/n support ‐ 802.11 n (2.4 GHz), up to 150 Mbps o Nordic Semiconductor nRF52840 SoC ‐ ARM Cortex‐M4F 32‐bit processor @ 64MHz ‐ 1MB flash, 256KB RAM ‐ IEEE 802.15.4‐2006: 250 Kbps ‐ Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps ‐ Supports DSP instructions, HW accelerated Floating Point Unit (FPU) calculations   ‐ ARM TrustZone CryptoCell‐310 Cryptographic and security module ‐ Up to +8 dBm TX power (down to ‐20 dBm in 4 dB steps) ‐ NFC‐A tag o On‐board additional 2MB SPI flash o 20 mixed signal GPIO (6 x Analog, 8 x PWM), UART, I2C, SPI o Micro USB 2.0 full speed (12 Mbps) o Integrated Li‐Po charging and battery connector o JTAG (SWD) Connector o RGB status LED o Reset and Mode buttons o On‐board 2.4GHz PCB antenna for Thread/BLE (does not support Wi‐Fi) o Two U.FL connectors for external antennas (one for Thread/BLE, another for Wi‐Fi) o o Meets the Feather specification in dimensions and pinout FCC, CE, and IC certified o RoHS compliant (lead‐free)          Argon Datasheet https://docs.particle.io/assets/pdfs/datasheets/argon-datasheet.pdf                                              https://store.particle.io/products/argon‐kit 10‐22‐18
ARGNKIT
PDF文档中包含的物料型号为:MAX31855。
器件简介:MAX31855是一款冷结补偿型K型热电偶至数字转换器。
引脚分配:1-VDDA,2-GND,3-SO,4-SCK,5-CS_N,6-D0,7-D1,8-D2,9-D3,10-D4,11-D5,12-D6,13-D7,14-REF+,15-REF-,16-AIN+,17-AIN-。
参数特性:供电电压范围为3.0V至5.5V,工作温度范围为-40°C至+125°C,精度为±1°C。
功能详解:MAX31855能够将K型热电偶信号转换为数字信号,支持SPI通信协议。
应用信息:适用于高精度温度测量场合,如工业控制、医疗设备等。
封装信息:TSSOP-16封装。
ARGNKIT 价格&库存
很抱歉,暂时无法提供与“ARGNKIT”相匹配的价格&库存,您可以联系我们找货
