BRN310KIT
BRN310KIT
    PARTICLE
    BORON 2G/3G KIT
BRN310KIT 数据手册
    Boron 2G/3G Kit   Note: Live in the United States? Check out the Boron LTE. See the cellular FAQ for 2G/3G country availability. The Boron GSM is a powerful 2G/3G enabled development kit that can act as either a standalone cellular endpoint or 2G/3G enabled gateway for Particle Mesh networks. It is based on the Nordic nRF52840 and has built-in battery charging circuitry so it’s easy to connect a Li-Po and deploy your local network in minutes. The Boron is great for connecting existing projects to the Particle Device Cloud or as a gateway to connect an entire group of local endpoints where Wi-Fi is missing or unreliable. All Particle hardware is designed from the ground up to work with the Device Cloud; a powerful set of tools and infrastructure to build, connect, and manage your IoT fleet. The Device Cloud for Particle Mesh will be priced by network. All Particle customers get 3 free months of Device Cloud access for micro networks using a cellular gateway. A micro network is defined as a network with 10 total devices and a single gateway. More pricing details to be released soon. In the meantime, check out our documentation. o Contents: o Boron 2G/3G dev board o Mini breadboard o Cellular flex antenna o 1800mAh Li‐Po battery o USB cable o Starter project includes two resistors (220 ohm), one red LED, and one photodiode o Specs: o u‐blox SARA U201 2G/3G modem ‐ HSPA/GSMqq with global hardware and SIM support ‐ 3GPP Release 7 ‐ Bands 800/850/900/1900/2100 MHz o Nordic Semiconductor nRF52840 SoC ‐ ARM Cortex‐M4F 32‐bit processor @ 64MHz ‐ 1MB flash, 256KB RAM ‐ IEEE 802.15.4‐2006: 250 Kbps ‐ Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps ‐ Supports DSP instructions, HW accelerated Floating Point Unit (FPU) calculations     ‐ ARM TrustZone CryptoCell‐310 Cryptographic and security module ‐ Up to +8 dBm TX power (down to ‐20 dBm in 4 dB steps) ‐ NFC‐A tag o On‐board additional 2MB SPI flash o 20 mixed signal GPIO (6 x Analog, 8 x PWM), UART, I2C, SPI o Micro USB 2.0 full speed (12 Mbps) o Integrated Li‐Po charging and battery connector o JTAG (SWD) Connector o RGB status LED o Reset and Mode buttons o Dual SIM support: Nano 4FF and MFF2 o U.FL connector for external antenna o Meets the Feather specification in dimensions and pinout o FCC and PTCRB certified o RoHS compliant (lead‐free)                                                          https://store.particle.io/products/boron‐2g‐3g‐kit 10‐22‐18
BRN310KIT 价格&库存
很抱歉,暂时无法提供与“BRN310KIT”相匹配的价格&库存,您可以联系我们找货
