BRN402
BRN402
    PARTICLE
    BORON LTE
BRN402 数据手册
          Boron LTE Note: Particle’s MVNO will provide support for LTE M1 connectivity in the US upon initial release. Not in the region? Check out the Boron 2G/3G Kit. See the cellular FAQ for details. The Boron LTE is a powerful LTE CAT-M1/NB1 enabled development board that can act as either a standalone cellular endpoint or LTE enabled gateway for Particle Mesh networks. It is based on the Nordic nRF52840 and has built-in battery charging circuitry so it’s easy to connect a Li-Po and deploy your local network in minutes. The Boron is great for connecting existing projects to the Particle Device Cloud or as a gateway to connect an entire group of local endpoints where Wi-Fi is missing or unreliable. All Particle hardware is designed from the ground up to work with the Device Cloud; a powerful set of tools and infrastructure to build, connect, and manage your IoT fleet. The Device Cloud for Particle Mesh will be priced by network. All Particle customers get 3 free months of Device Cloud access for micro networks using a cellular gateway. A micro network is defined as a network with 10 total devices and a single gateway. More pricing details to be released soon. In the meantime, check out our documentation. o Specs: o u‐blox SARA R410 LTE modem ‐ LTE CAT M1/ NB1 module with global hardware support (MVNO support for US only) ‐ 3GPP Release 13 LTE Cat M1 o Nordic Semiconductor nRF52840 SoC ‐ ARM Cortex‐M4F 32‐bit processor @ 64MHz ‐ 1MB flash, 256KB RAM ‐ IEEE 802.15.4‐2006: 250 Kbps ‐ Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps ‐ Supports DSP instructions, HW accelerated Floating Point Unit (FPU) calculations ‐ ARM TrustZone CryptoCell‐310 Cryptographic and security module ‐ Up to +8 dBm TX power (down to ‐20 dBm in 4 dB steps) ‐ NFC‐A tag o On‐board additional 2MB SPI flash o 20 mixed signal GPIO (6 x Analog, 8 x PWM), UART, I2C, SPI o Micro USB 2.0 full speed (12 Mbps) o Integrated Li‐Po charging and battery connector o JTAG (SWD) Connector o RGB status LED o Reset and Mode buttons o Dual SIM support: Nano 4FF (unpopulated) and MFF2 o U.FL connector for external antenna o o Meets the Feather specification in dimensions and pinout FCC and PTCRB certified o RoHS compliant (lead‐free   https://store.particle.io/products/boron‐lte 10‐23‐18
BRN402 价格&库存
很抱歉,暂时无法提供与“BRN402”相匹配的价格&库存,您可以联系我们找货
