SPKBTTN
SPKBTTN
    PARTICLE
    INTERNET BUTTON
SPKBTTN 数据手册
The Internet Button   The Internet Button is a ready‐to‐use IoT device with sensors, LEDs, and more. Place orders online, send  emails, receive notifications, track feedback, and develop hundreds of other applications        The IoT at the push of a button The Internet Button is your IoT trigger to send and receive events, automating the things around you. The  Particle Cloud makes it happen.   Simple and easy set up Setting up the Internet Button isn't complicated. Change one line of code to change the actions of the button.  Connect via IFTTT and you can make phone calls, send texts and purchase items online in just minutes.  More than just a button Underneath 4 tactile buttons are a strip of controllable RGB LEDs, a speaker and even an accelerometer.  Easily prototype any number of IoT applications.       Build IoT Software Start building IoT software for The Internet Button with straightforward developer toolkits. Use software to  setup devices, add libraries and efficiently debug any code.  Comprehensive Management Tools Focus on your product. Resolve any issues and troubleshoot with our developer tools. The Particle Console  and easy‐to‐use mobile apps both manage and monitor your devices.  Button specs         11 individually controllable RGB LEDs  ADXL362 3‐axis accelerometer  4 tactile buttons for D‐pad style interactions  Female socket for connection to Photon  Additional female headers for adding extra actuators and sensors  Photon specs      Particle P0 Wi‐Fi module  Broadcom BCM43362 Wi‐Fi chip  STM32F205 120Mhz ARM Cortex M3  FCC/CE/IC certified    Internet Button ‐ Library  If you're already logged into Build.particle.io then you can jump directly to the library to get going quickly and  easily with the InternetButton library, which wraps all the features in easy‐to‐use functions.  Examples include:  1. 2. 3. 4. 5. 6. 7. 8. 9. Blink an LED ‐ How to control the smart LEDs on this board  Blink all the LEDs ‐ An extension on the simplest case  LEDs and Buttons ‐ How to read the buttons on the Button, and make LEDs blink with them  Good Combination ‐ A set of button and LED conditionals that I happen to like and use frequently  Motion ‐ The Internet Button also has an accelerometer on it to measure motion‐ this shows how the  related functions work  Orientation ‐ How to use the accelerometer functions to determine the orientation  Internet ‐ Send that data out to the world!  Making Music ‐ Learn how to play notes and songs with your Button  Release Firmware ‐ Big, complicated set of epic.        Internet Button ‐ Top    Internet Button ‐ Bottom        Internet Button ‐ Specifications          Operating voltage: USB or External DC of 3.3 to 5.5VDC  Dimensions: 2.6" x 2.6"   11 individually controllable RGB LEDs  ADXL362 3‐axis accelerometer  4 tactile buttons for D‐pad style interactions  Female socket for connection to a Particle device  Additional female headers for adding extra actuators and sensors  Backward compatible with the Core                                              https://www.particle.io/products/hardware/internet‐button 11‐2‐17
SPKBTTN 价格&库存
很抱歉,暂时无法提供与“SPKBTTN”相匹配的价格&库存,您可以联系我们找货
