RLYSHIELD
RLYSHIELD
    PARTICLE
    RELAY SHIELD
RLYSHIELD 数据手册
      Relay Shield The Relay Shield allows you to take over the world, one electric appliance at a time. Want to control a lamp, fan, coffee machine, aquarium pumps or garden sprinklers? Then this is a solution for you! The shield comes with four relays that are rated at a max of 220V @10Amp allowing you to control any electric appliance rated at under 2000 Watts. You are not just limited to an appliance though; any gadget that requires high voltage and/or a lot of current can be controlled with this shield. We have even provided a small prototyping area around the shield for you to add more components or connectors. A temperature sensor to go along with your brewer, maybe? IMPORTANT: This shield provides regulated power (5V) to the seated Particle device and relays. However, it does not support power to the devices controlled by the relays. Relay Shield - Library If you're already logged into Build.particle.io then you can jump directly to the library to get going quickly and easily with the RelayShield library, which wraps all the features in easy-to-use functions. Examples include: 1. Blink a Relay - How to turn a relay on and off 2. Blink all the Relays - An extension on the simplest case 3. Internet Relays - Creating Particle.function()s so that you can turn relays on and off over the Internet Relay Shield - Operation The schematic for the relay shield is simple and self explanatory. The shield has four relays that are controlled by pins D3, D4, D5 and D6 on the Particle device. Each relay is triggered via a NPN transistor that takes a control signal from the Particle device and switches the relay coil ON and OFF, which in turn makes or breaks the electrical contact on the output. There is also a fly-back diode connected across the coil to help protect the transistor from high voltage transients caused during switching. NOTE: On the under side of the relay shield (top center), you will see 4 solder pads that are by default bridged via traces. You can scratch off the trace to disconnect the control pin from the preassigned ones (D3 to D6) and wire up based on your project requirement. Relay Shield Schematic – Control The relays are SPDT (Single Pole Double Throw) type, which means they have three terminals at the output: COMMON (COMM), Normally Open (NO) and Normally Closed (NC). We can either connect the load in between the COMM and NO or COMM and NC terminals. When connected in between COMM and NO, the output remains open/disconnected when the relay is turned OFF and closes/connects when the relay is turned ON. In the later case, the output remains closed/connected when the relay is OFF and opens/disconnects when the relay is ON. Relay Shield Schematic - Power Supply The Relay Shield uses a high efficiency RT8259 switch mode voltage regulator that provides a constant 5V to the Particle device and the relays. The regulator is rated at 1.2A max output current which is ample enough to power the Particle device, the four relays and still have left over for other things you may decided to connect later. You can power the shield via the 5.5mm barrel jack or through the screw terminal. There is a reverse polarity protection diode in place so that you don't fry the electronics by plugging in the wires in reverse! Here is an example setup to control a light bulb. The relay acts like a switch which is normally open and when pin D3 on the Particle device is turned HIGH, it activates Relay 1 thereby closing the circuit on the light bulb and turning it ON. Ta dah! Relay Shield - Sample Setup Relay Shield - Sample Code int RELAY1 = D3;  int RELAY2 = D4;  int RELAY3 = D5;  int RELAY4 = D6;    void setup()  {     //Initilize the relay control pins as output     pinMode(RELAY1, OUTPUT);     pinMode(RELAY2, OUTPUT);     pinMode(RELAY3, OUTPUT);     pinMode(RELAY4, OUTPUT);     // Initialize all relays to an OFF state     digitalWrite(RELAY1, LOW);     digitalWrite(RELAY2, LOW);     digitalWrite(RELAY3, LOW);     digitalWrite(RELAY4, LOW);       //register the Particle function     Particle.function("relay", relayControl);  }    void loop()  {     // This loops for ever  }    // command format r1,HIGH  int relayControl(String command)  {    int relayState = 0;    // parse the relay number    int relayNumber = command.charAt(1) ‐ '0';    // do a sanity check    if (relayNumber  4) return ‐1;      // find out the state of the relay    if (command.substring(3,7) == "HIGH") relayState = 1;    else if (command.substring(3,6) == "LOW") relayState = 0;    else return ‐1;      // write to the appropriate relay    digitalWrite(relayNumber+2, relayState);    return 1;  } An example API request to this function would look something like this: POST /v1/devices/{DEVICE_ID}/relay    # EXAMPLE REQUEST  curl https://api.particle.io/v1/devices/0123456789abcdef/relay \    ‐d access_token=123412341234 ‐d params=r1,HIGH Relay Shield - Specifications (v3.x.x)        Operating voltage: 7 to 20V DC Current consumption: 150mA min to 290mA max (at 9V DC) Relay Max Voltage: 220V AC Relay Max Current: 10Amp at 125V AC Relay Part Number: JS1-5V-F Dimensions: 6.0" x 1.7" Weight: 80 gms Drill Template > https://docs.particle.io/assets/images/shields/relay-shield/relay-shield-template.pdf                                 https://docs.particle.io/datasheets/particle‐shields/#relay‐shield 10‐19‐17
RLYSHIELD 价格&库存
很抱歉,暂时无法提供与“RLYSHIELD”相匹配的价格&库存,您可以联系我们找货
