44R02-2131-150
44R02-2131-150
    POWERDYNAMICS
    PWR ENT RCPT IEC 320-C13 PNL QC
44R02-2131-150 数据手册
6 5 4 3 2 MATERIAL AND FINISH F+0.2 32.0 Insulator: Polycarbonate or Thermoplastic, black, UL-94V-0 rated. Solder Terminals: Brass, Tin plated. D 1 4.80 TYP. 2.8x3.3 TYP. D ELECTRICAL SPECIFICATIONS: Rated current: 10A Rated voltage: 250VAC 32.5+0.2 V D E Rated current: 20A Rated voltage: 250VAC No of Port 2 3 4 5 6 7 C C L 51.2 75.4 99.6 123.2 147.2 171.2 R2.5 TYP. E 48.0 72.0 96.0 120.0 144.0 168.0 35.0 2.5+0.3 TYP. REPLACE WITH CORRESPONDING PANEL THICKNESS L C E 5.0+0.5 TYP. 1) NO OF PORT (SEE CHART ABOVE) 15.8-0.5 4.00 0.8 TYP. B PB PB DF PB 1/30/08 D CHNG DIM E & F FOR 3 & 4 PORTS 1/24/05 C ADD 1.0mm PANEL THICKNESS PB PB PB TD PB REV'D DIM L, E, F 5/14/04 B TD 2/28/03 CHNG. UL RATING TO 20A CHANGE 24.0 14.0±0.2 A DATE REVISIONS CHNG CHCK APPR 2) PANEL THICKNESS REV A RECOMMENDED PANEL CUTOUT F 48.3 72.2 96.2 120.3 144.4 168.4 ORDERING CODE: 44R02-__ 131 - __ __ __ 1 2 B A+0.2 3 US 6 10.5±0.5 TYP. 23.0-0.5 29.5+0.5 TOLERANCE UNLESS OTHERWISE SPECIFIED X ± 1 X.X ± 0.4 X.XX ± 0.20 P/N A MAX. PANEL THICKNESS 44R02-X131-100 1.0 1.0 1.5 DRAWN 44R02-X131-150 1.5 DT BY 2.5 44R02-X131-250 2.5 CHECK PB BY ADDITIONAL PANEL THICKNESS APPR AVAILABLE ON REQUEST BY 5 4 3 DATE: 1/15/03 DATE: 1/15/03 DATE: Phone: 973 560-0019 Whippany, New Jersey Fax: 973 560-0076 A PART: IEC 60320 C13 STRIP APPL. OUTLET; SNAP-IN, 4.8 Q.C. TERMINAL PART #: SIZE: SCALE: SHEET 1 of 1 44R02-X131-XXX A NTS 2 ALL DIMENSIONS FOR REFERENCE ONLY DIMENSIONS ARE IN MILLIMETERS 1 REV: D
44R02-2131-150 价格&库存
很抱歉,暂时无法提供与“44R02-2131-150”相匹配的价格&库存,您可以联系我们找货
