DF07F4BN/AA
DF07F4BN/AA
    POSITRONIC(宝西)
    7 位置 连接器 镀金
DF07F4BN/AA 数据手册
Interconnection Systems DRAGONFLY High Density Signal and Power Connectors Positronic Industries www.connectpositronic.com High Density Signal and Power Interconnection Systems Dragonfly High Density Signal/ Power Interconnection Systems Unless otherwise specified, dimensional tolerances are: 1) Male contact mating diameters 2) Contact termination diameters 3) All other diameters 4) All other dimensions : ±0.03 [0.001] : ±0.08 [0.003] : ±0.13 [0.005] : ±0.38 [0.015] Dimensions are in millimeters [inches]. All dimensions are subject to change. CATALOG NUMBER: A-002 rev. B2 Products described within this catalog may be protected by one or more of the following U.S. patents: #4,721,472 #4,900,261 #5,255,580 #5,329,697 Patented in Canada, 1992 #6,260,268 Other Patents pending. Unless otherwise stated, Positronic code and part number are marked on each connector. The contents of the code are subjected to the discretion of Positronic and it is for internal use only. Marking may be done on either side or both sides of the connector. Positronic believes the data contained herein to be reliable. Since the technical information is given free of charge, the user employs such information at his own discretion and risk. Positronic assumes no responsibility for results obtained or damages incurred from use of such information in whole or in part. Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com High Density Signal and Power Interconnection Systems Typical Connection Systems System 1 System 2 Straight Board Mounting to Cable Straight Board Mounting to Right Angle Board Mounting DF04F3N DF07M30 DF04M00 with crimp contacts installed. DF07F4BN System 3 System 5 Right Angle Board Mounting to Cable Cable Connector and Hood with Cable Clamp DF07F0W1 Hood Top Hood Insert DF16F4BN DF16M00 with crimp contacts installed. Wire Clamp System 4 Cable to Cable Hood Bottom 2x Cable Clamp Screws DF07M00 with crimp contacts installed. 2x Hood Screws DF07F00 with crimp contacts installed. 1 Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com Connector Versions and Technical Characteristics Connector Versions ing Com n! o So Version 03 Power Contact Connector Version 04 Mixed Density Contact Connector Three (3) Size 16 Power Contacts Two (2) Size 16 Power Contacts and Two (2) Size 22 Signal Contacts Specify Code 04 in Step 2 Version 07 Power Contact Connector Seven (7) Size 16 Power Contacts Specify Code 07 in Step 2 Version 10 Signal/ Power Contact Connector Version 16 High Density Signal Contact Connector Ten (10) Size 20 Signal/ Power Contacts Specify Code 10 in Step 2 Sixteen (16) Size 22 Signal Contacts Specify Code 16 in Step 2 Technical Characteristics Materials and Finishes: Insulator: Glass-filled nylon, UL 94V-0, green for versions 07, 10 and 16. Black color for version 04. Hood (W1): Hood (W2): Polypropylene, UL 94V-0. Black color. Glass-filled nylon, UL 94V-0. Black color. Contacts: Precision machined copper alloy with gold over nickel plate. Push-on fasteners: Copper alloy with tin plate. Screws: Steel with zinc plate and chromate seal. Electrical Characteristics: Contact Current Rating: Size 16 Contacts: 20.0 amperes, continuous. Size 20 Contacts: 7.5 amperes, nominal. 12.0 amperes, continuous with AWG 18 wires. Size 22 Contacts: 3.0 amperes, nominal. Initial Contact Resistance Max (per IEC 512-2, Test 2b) : Size 16 Contacts: 0.003 ohms Size 20 Contacts: 0.005 ohms. Size 22 Contacts: 0.005 ohms. Insulator Resistance: 5 G ohms (per IEC 512-2, Test 3a). Voltage Proof: Size 16 Contacts: 1500 V r.m.s. Size 20 Contacts: 1000 V r.m.s. Size 22 Contacts: 1000 V r.m.s. Working Voltage: Size 16 Contacts: 500 V r.m.s. Size 20 Contacts: 333 V r.m.s. Size 22 Contacts: 333 V r.m.s. Mechanical Characteristics: Connection Systems: Connector provides cable to cable, cable to printed board and printed board to printed board mating systems. Locking Systems: Insulators provide locking between cable to cable and cable to printed board applications. Polarization: Provided in insulator design. Removable Contacts: Install contact from rear of insulator, release with extraction tool from front of insulator. Female contacts feature “closed entry” 1,000 cycle design. (Size 16 contact tested to 10,000 cycles. See page 3.) “Open entry” 500 cycle design also available. Fixed Contacts: Removable Contact Retention in Insulator Size 16 Contacts: 45 N [10 lbs.] Min. Size 20 Contacts: 27 N [ 6 lbs.] Min. Size 22 Contacts: 27 N [ 6 lbs.] Min. Fixed Contact Retention in Insulator Size 16 Contacts: 45 N [10 lbs.] Min. Size 20 Contacts: 27 N [ 6 lbs.] Min. Size 22 Contacts: 27 N [ 6 lbs.] Min. Sequential Mating: Consult factory for details. Recognized: UL File E49351. Climatic Characteristic: Working temperature: -55°C to +105°C. Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com Size 16 female contact features “closed entry” 1,000 cycles design for both straight and right angle (90°) PCB mount. Size 22 female contact features “open entry” design. “Closed entry” available on request. Size 20 female contact features both “closed entry” and “open entry” design options. See ordering informations. 2 Temperature Rise Curve and Contact Performance Temperature Rise Curve Tested per IEC 512-3, Test 5a Above curves developed separately using (a) DF04 connectors and AWG 12 wires, and (b) DF07 connectors and AWG 12 wires and (c) DF10 connectors and AWG 18 wires. All power contacts under load. 10,000 Cycles Contact Performance Contact resistance tested per IEC 512-2, Test 2b Above curves developed using DF07 connectors fully populated with size 16 contacts. This information is supplied for reference. Contact wear and change in contact resistance may vary from one application to another. Contact technical sales to discuss details. 3 Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com Dragonfly Version 03 Female Cable Connector 3A A-002 Rev B2 Positronic Industries, Inc. www.connectpositronic.com Dragonfly Version 03 Male Panel Connector 3B A-002 Rev B2 Positronic Industries, Inc. www.connectpositronic.com Dragonfly Version 04 Straight and Right Angle (90°) PCB Mount Connectors DF04 Outline Dimensions PCB Mount Connector Male Female Contact Termination Dimensions See Step 4 of Ordering Information Straight PCB Mount Specify Code 3 in Step 4 Male Power contacts Female Power contacts Signal contacts Signal contacts Right Angle (90°) PCB Mount Specify Code 4 in Step 4 Male Power contacts Female Signal contacts Power contacts Not supplied with alignment bar Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com 4 Signal contacts Dragonfly Version 04 Right Angle (90°) PCB Mount (Longer Insulator Version) and Removable Contact Cable Connectors DF04 Outline Dimensions PCB Mount Connector (Longer Insulator) Male only Contact Termination Dimensions See Step 4 of Ordering Information Right Angle (90°) PCB Mount Specify Code 42 in Step 4 Power contacts Signal contacts Removable Contact Cable Connectors Specify Code 0 in Step 4 of Ordering Information Outline Dimensions Male Female Version 04 Removable contacts should be allowed to float after terminated and installed in connector body. This enables superior mating performance. Consult factory if alignment insert for male contacts is desired. 5 Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com Dragonfly Version 07 PCB Mount Connectors and Removable Contact Cable Connectors DF07 Outline Dimensions Male PCB Mount Connector Female Contact Termination Dimensions See Step 4 of Ordering Information Male Male Straight PCB Mount Specify Code 3 in Step 4 Right Angle (90°) PCB Mount Specify Code 4 in Step 4 Female Female Integrated alignment bar and angle bracket, shown for reference only. (Specify code B in Step 5) Removable Contact Cable Connectors Specify Code 0 in Step 4 of Ordering Information Outline Dimensions Male Female Version 07 Removable contacts should be allowed to float after terminated and installed in connector body. This enables superior mating performance. Consult factory if alignment insert for male contacts is desired. Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com 6 Dragonfly Versions 10 and 16 PCB Mount Connectors and Contact Termination Dimensions DF10 and DF16 Outline Dimensions Male PCB Mount Connector Female Removable Contact Cable Connectors Specify Code 0 in Step 4 of Ordering Information Male Female Removable contacts should be allowed to float after terminated and installed in connector body. This enables superior mating performance. Consult factory if alignment insert for male contacts is desired. Version 10 PCB Mount Contact Termination Dimensions Straight PCB Mount Specify Code 3 in Step 4 Right Angle (90°) PCB Mount Specify Code 4 in Step 4 Integrated alignment bar and angle bracket shown for reference only. (Specify code B in Step 5) 7 Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com Contact Termination Dimensions and Contact Hole Patterns for PCB Mount Version 16 PCB Mount Contact Termination Dimensions Straight PCB Mount Male Specify Code 3 in Step 4 Female Male Right Angle (90°) PCB Mount Female Specify Code 4 in Step 4 Integrated alignment bar and angle bracket shown for reference only. (Specify code B in Step 5) Version 04 PCB Mount - Contact Hole Patterns Contact Hole Pattern for Straight PCB Mount Contact Hole Pattern for Right Angle (90°) PCB Mount For both male and female connectors. Version 07 PCB Mount - Contact Hole Patterns Contact Hole Pattern for Straight PCB Mount Contact Hole Pattern for Right Angle (90°) PCB Mount For both male and female connectors. Suggested Ø2.00±0.08 [0.079±0.003] holes for mounting connector with push-on fasteners. Suggested Ø2.54 [0.100] holes for mounting connector with screws. Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com 8 Contact Hole Patterns for PCB Mount Version 10 PCB Mount - Contact Hole Patterns Contact Hole Patterns for Straight PCB Mount Contact Hole Pattern for Right Angle (90°) PCB Mount For both male and female connectors. Contact Hole Patterns for Version 16 PCB Mount Contact Hole Pattern for Straight PCB Mount Contact Hole Pattern for Right Angle (90°) PCB Mount For both male and female connectors. Suggested Ø2.00±0.08 [0.079±0.003] holes for mounting connector with push-on fasteners. Suggested Ø2.54 [0.100] holes for mounting connector with screws. 9 Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com Panel Mount Option, Mounting Hardware and Installation Tools Panel Mount Option For Male Crimp Connectors of Versions 07, 10 and 16 only (Specify Code P in Step 5) Panel Cutout Flange Dimensions Suggested Installation to Panel: Suggested installation of connector to panel with screws and nuts. (Screws and nuts shown for reference only) Materials and Finishes: Flange: Glass-filled nylon, UL 94V-0. Flange supplied factory installed to connector Push-on Fasteners Available on all connectors except Version 04 code 42 contacts Straight PCB mount version Right Angle (90°) PCB mount version Specify code N in Step 5 Specify code BN in Step 5 Material: Copper alloy with tin plate. Mounting Screws Ordering Information Connector Variant DF04*3/93* DF04*4/42* Screw Part Number Screw Length “A” Recommended PCB Thickness 4546-7-1-16 6.35 [0.250] 2.20 [0.087] to 3.50 [0.138] 4546-7-2-16 7.93 [0.312] 3.60 [0.142] to 4.50 [0.177] 4546-32-1-16 8.00 [0.315] 1.40 [0.055] to 4.00 [0.157] 4546-32-2-16 10.00 [0.393] 3.00 [0.118] to 6.00 [0.236] DF07*3/93* DF10*3/98* DF16*3/98* 4546-7-1-16 6.35 [0.250] 1.40 [0.055] to 3.00 [0.118] 4546-7-2-16 7.93 [0.312] 3.00 [0.118] to 4.00 [0.157] DF07/10/16*4* 4546-7-0-16 4.78 [0.188] 2.00 [0.079] maximum Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com 10 Compliant Press-Fit Terminations PCB Straight Mount Connector Installation Tools Ordering Information Catalog Part Number Seating Tool Part Number DF04F930 9513-309-21 DF04M930 9513-309-22 DF07F930 9513-309-25 DF07M930 9513-309-24 DF10F980 9513-309-26 DF10M980 9513-309-27 DF16F980 9513-309-20 DF16M980 9513-309-23 Support Tool Part Number 9513-404-4 9513-404-5 9513-404-6 9513-404-3 Connector Hood Hood - Top and Side Opening For Versions 07, 10 and 16 only Specify code W1 in Step 5 Outline Dimensions Hood comes supplied with extra insert for unused opening. Note: “W1” Hood may not accommodate fully populated connector using thick insulation 12, 14 and 16 AWG wires. Customer review recommended Materials and Finishes: Hood Top and Bottom, Insert: Polypropylene, UL 94V-0, black. Cable Clamp: Steel with nickel plate. Hood and Cable Clamp Screws: Steel with black oxide or Steel with zinc plate and chromate seal. Hood - Top Opening - Wide Body For Versions 07, 10 and 16 only (for partially and fully populated connector) Specify code W2 in Step 5 Outline Dimensions Note: “W2” Hood are able to accommodate fully populated connector using thick insulation 12, 14 and 16 AWG wires. Materials and Finishes: Hood: Glass-filled nylon, UL 94V-0, black. Cable Clamp: Steel with nickel plate. Hood and Cable Clamp Screws: Steel with black oxide or Steel with zinc plate and chromate seal. Top opening: 16.50 [0.650] x 9.00 [0.354] (for reference only) 11 Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com Removable Crimp Contacts Size 16 contact Rated 20.0 amperes (“Closed entry” 1,000 cycles minimum) Male Contact Male Contact Female Contact MC112N MC114N MC116N MC120N Female Contact (Closed entry) Wire Size AWG [mm2] ØA FC112N2 12 [4.0] 2.49 [0.098] N/A FC114N2 14-16 [2.5-1.5] 2.06 [0.081] 2.67 [0.105] FC116N2 16-18 [1.5-1.0] 1.70 [0.067] 2.36 [0.093] FC120N2 20-22-24 [0.5-0.3-0.25] 1.14 [0.045] 1.73 [0.068] Note: Size 16 contacts tested to 10,000 cycles performance as shown in graph on page 3. This does not insure similar performance under different conditions. Wear in mating area of contacts does occur. Customer review recommended. ØB Size 20 contact Rated up to 12.0 amperes (“Closed entry” 1,000 cycles minimum) Male Contact MC718N / MC720N Contact Part Number MC718N FC718N2 FC718N7 *MC720N *FC720N2 *FC720N7 Female Contact FC718N2 / FC720N2 (Closed entry) Wire Size AWG [mm2] ØA 18 [1.0] 1.40 [0.055] 1.40 [0.055] 1.37 [0.054] N/A 20-22-24 [0.5-0.3-0.25] 1.14 [0.045] 1.73 [0.068] ØB C 18.80 [0.740] 18.24 [0.718] 18.80 [0.740] 18.80 [0.740] 19.41 [0.764] 18.80 [0.740] Female Contact FC718N7 / FC720N7 (Open entry, 500 cycles) * Contact rated 7.5 amperes Size 22 contact Rated 3.0 amperes (“Closed entry” 1,000 cycles minimum) MC422N Male Contact MC422N FC422N7 (Open entry, 500 cycles) FC422N2 (Closed entry) Female Contact FC422N2 FC422N7 Wire Size AWG [mm2] ØA ØB 22 [0.3] 0.89 [0.035] 1.42 [0.056] Please use correct wire size and it should be smaller than ØA of the contact. Consult factory for other contact sizes, materials and termination styles. Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com 12 Connector Ordering Information Specify complete connector by following step 1 to 5 Step 1 Example DF 2 3 4 5 6 07 M 3 N /AA STEP 1 : Basic Series XXX Consult factory for customization of connectors. Example: Selective loading, sequential mating, etc. STEP 2 : Connector Versions Mixed density contact connector two (2) size 16 power contacts and two (2) size 22 signal contacts Power contact connector seven (7) size 16 power contacts Signal/ power contact connector ten (10) size 20 signal/ power contacts High density signal contact connector sixteen (16) size 22 signal contacts STEP 6: Environmental Compliance Options /AA : Note: Compliant per EU Directive 2002/95/EC (RoHS) If compliance to environmental legislation is not required, this step will not be used. Example: DF16F30 STEP 5 : Mounting Style, Hoods, Panel Mount 0 : N : B : BN : W1 : W2 : P : STEP 3 : Connector Gender M : Male F : Female STEP 4: Type of Contact 0 : *3 : 31 : *4 : 41 : 42 : 93 : 98 : - STEP 7 : Special Options DF : Dragonfly Series 04 : 07 : 10 : 16 : 7 Removable contact. (contacts ordered separately). Solder, straight PCB mount. Solder, open-entry, straight PCB mount. (For female connectors of version 10 only.) Solder, right angle (90°) PCB mount. Solder, open-entry, right angle PCB mount. (For female connectors of version 10 only.) Solder, right angle (90°) PCB mount. (For version 04 male only. Using Longer Insulator.) Press-fit, compliant termination straight pcb mount. (For versions 04 and 07 only.) Press-fit, compliant termination straight pcb mount. (For versions 10 and 16 only.) No hardware. For mounting connector with self-tapping screws. (Order screws separately.) Push-on fasteners. Plastic 90° Mounting Bracket. For versions 07, 10 and 16 only. Plastic 90° mounting bracket with push-on fasteners. For versions 07, 10 and 16 only. Top and side opening hood. For versions 07, 10 and 16 only. Top opening hood-wide body For versions 07, 10 and 16 only. Panel mount adaptor for male crimp connectors of versions 07, 10 and 16 only. Note: For suggested straight mount pcb holes sizes of compliant press-fit connectors, please consult factory. *Standard female contact is closed-entry for Versions 07 and 10. *Standard female contact is open-entry for Version 16. Recommended Tools for Crimp Contacts Contact Extraction Tool Contact Insertion Tool Contact Size Contact Extraction Tool Contact Insertion Tool Size 16 9081-0 9099-0 9501-0 with 9502- 1 positioner Cycle-Controlled Step Adjustable Hand Crimp Tool Hand Crimp Tool Size 20 9081-2 9099-4 9507-0 with 9502-21 positioner (Male) 9507-0 with 9502-22 positioner (Female) Size 22 9081-3 9099-1 9507-0 with 9502-12 positioner (Male) 9507-0 with 9502-13 positioner (FC422N2) 9507-0 with 9502-23 positioner (FC422N7) Semi-Automatic Crimp Machine 9550-0 9550-1 Consult factory for details on semi-automatic crimp machine. Above tools were shown for reference only. 13 Positronic Industries, Inc www.connectpositronic.com www.positronicasia.com COMPLIANT PRESS-FIT CONNECTORS FOR CONNECTOR VERSIONS 04, 07, 10 AND 16 SUGGESTED PRINTED BOARD HOLE SIZES COMPLIANT PRESS-FIT CONNECTORS Traditionally, tin-lead has been a popular plating for PCB holes. However, many PCB hole platings must now be RoHS Compliant. Positronic is pleased to offer PCB HOLE SIZE FOR RoHS PCB plating as shown below. BI-SPRING COMPLIANT PRESS-FIT CONTACT HOLE BOARD TYPE CONTACT SIZE RECOMMENDED DRILL HOLE SIZE RECOMMENDED PLATING FINISHED HOLE SIZES TIN-LEAD SOLDER PCB 16 ø1.750±0.025 [ø0.0689±0.0010] 15μ [0.0006] minimum solder over 25μ [0.0010] min. copper ø1.600+0.090-0.060 [ø0.0630+0.0035-0.0024] “Bi-Spring” Termination RoHS PCB PLATING OPTIONS COPPER PCB 16 ø1.750±0.025 [ø0.069±0.001] IMMERSION TIN PCB 16 ø1.750±0.025 [ø0.069±0.001] IMMERSION SILVER PCB 16 ø1.750±0.025 [ø0.069±0.001] ELECTROLESS NICKEL/ IMMERSION GOLD PCB 16 ø1.750±0.025 [ø0.069±0.001] 25μ [0.0010] min. copper 0.85±0.15μ [0.000033±0.000006] immersion tin over 25μ [0.0010]min. copper 0.34±0.17μ [0.000013±0.000007] immersion silver over 25μ [0.0010] min. copper 0.05μ [0.000002] min. immersion gold over [4.5±1.5μ [0.000177±0.000059] electroless nickel per IPC-4552 over 25μ [0.0010]min. copper ø1.600+0.090-0.060 [ø0.0630+0.0035-0.0024] ø1.600+0.090-0.060 [ø0.0630+0.0035-0.0024] ø1.600+0.090-0.060 [ø0.0630+0.0035-0.0024] ø1.600+0.090-0.060 [ø0.0630+0.0035-0.0024] OMEGA COMPLIANT PRESS-FIT CONTACT HOLE BOARD TYPE CONTACT SIZE RECOMMENDED DRILL HOLE SIZE RECOMMENDED PLATING FINISHED HOLE SIZES TIN-LEAD SOLDER PCB 20 22 ø1.150±0.025 [ø0.0453±0.0010] 15μ [0.0006] minimum solder over 25μ [0.0010] min. copper ø1.000+0.090-0.060 [ø0.0394+0.0035-0.0024] COPPER PCB 20 22 ø1.19±0.025 [ø0.047±0.001] IMMERSION TIN PCB 20 22 ø1.19±0.025 [ø0.047±0.001] IMMERSION SILVER PCB 20 22 ø1.19±0.025 [ø0.047±0.001] ELECTROLESS NICKEL/ IMMERSION GOLD PCB 20 22 ø1.19±0.025 [ø0.047±0.001] PRESS-FIT CONTACT HOLE Note: For PCB plating compositions not shown, consult Technical Sales. RoHS PCB PLATING OPTIONS Note: DF04 DF07 DF10 DF16 - uses uses uses uses size size size size 16 16 20 22 25μ [0.0010] min. copper 0.85±0.15μ [0.000033±0.000006] immersion tin over 25μ [0.0010]min. copper 0.34±0.17μ [0.000013±0.000007] immersion silver over 25μ [0.0010]min. copper 0.05μ [0.000002] min. immersion gold over 4.5±1.5μ [0.000177±0.000059] electroless nickel per IPC-4552 over 25μ [0.0010] min. copper ø1.09±0.05 [ø0.043±0.002] “Omega” Termination ø1.09±0.05 [ø0.043±0.002] ø1.09±0.05 [ø0.043±0.002] ø1.09±0.05 [ø0.043±0.002] bi-spring press-fit and size 22 omega press-fit contacts. bi-spring press-fit contacts. omega press-fit contacts. omega press-fit contacts. A-002 Rev. B2 Positronic Industries, Inc. www.connectpositronic.com NORTH AMERICAN SALES OFFICES United States, Springfield, Missouri Factory and Sales Office 417 866 2322 Puerto Rico Sales Office 800 641 4054 Mexico Sales Office 800 872 7674 Canada Sales Office 800 327 8272 France, Auch Factory and Sales 335 6263 4491 Northern France Sales Office 331 4588 1388 Southern France Sales Office 335 6263 4491 Italy Sales Office 3902 5411 6106 Germany Sales Office 4923 5163 4739 United Kingdom Sales Office 44 1993 831 939 contact@connectpositronic.com jchalaux@connectpositronic.com plafon@connectpositronic.com rmagni@connectpositronic.com cbouche@connectpositronic.com lbridwell@connectpositronic.com Europe & Middle East Technical Agents: Finland, United Kingdom, Scotland, Israel, Norway, Sweden, Turkey and the Ukraine. ASIA / PACIFIC SALES OFFICES Singapore Factory, Sales and Engineering Office Singapore +65 6842 1419 Japan +813 5812 7720 South Korea +82 31 909 8047 India +91 20 2439 4810 Taiwan +886 2 2937 8775 China Zhuhai (Factory) +86 756 362 6466 Beijing & Xian +86 29 8839 5306 Shenzhen +86 755 2643 7578 Shanghai +86 158 2907 9779 Malaysia +60 4 644 9688 New Zealand +64 3 358 5154 Australia +61 2 4362 3477 singapore@connectpositronic.com japan@connectpositronic.com korea@connectpositronic.com india@connectpositronic.com taiwan@connectpositronic.com china@connectpositronic.com xian@connectpositronic.com shenzhen@connectpositronic.com shanghai@connectpositronic.com newzealand@connectpositronic.com australia@connectpositronic.com POSITRONIC INDUSTRIES, INC 423 N Campbell Avenue, P O Box 8247, Springfield, MO 65801, USA Telephone: 1 417 866 2322 Fax: 1 417 866 4115 Email: info@connectpositronic.com POSITRONIC INDUSTRIES, SAS Zone Industrielle Est, 46 Route d’Engachies, F32020, Auch Cedex 9, France Telephone: 335 62 63 44 91 Telecopieur: 335 62 63 51 17 Email: contact@connectpositronic.com POSITRONIC ASIA PTE LTD 3014A Ubi Road 1 # 07-01 Singapore 408703 Telephone: 65 6842 1419 Fax: 65 6842 1421 Email: singapore@connectpositronic.com www.connectpositronic.com Positronic Industries www.connectpositronic.com DRAGONFLY EUROPEAN SALES OFFICES info@connectpositronic.com
DF07F4BN/AA 价格&库存
很抱歉,暂时无法提供与“DF07F4BN/AA”相匹配的价格&库存,您可以联系我们找货
DF07F4BN/AA
    • 1+74.712701+9.56882
    库存:4
