MAX-BR1-MINI-LTE-US-T-PRM
    PEPLINK
    3G/4G HSPA+,LTE 路由器 以太网,LAN,WAN
MAX-BR1-MINI-LTE-US-T-PRM 数据手册
BR1 Mini 1x Ethernet LAN port with 802.3at PoE input Power Port with GPIO & Ignition Sensing1 1x LTE Modem 1x Ethernet WAN/LAN port1 Specifications WAN Interface 1x 10/100/1000M Ethernet1 1x Embedded Cellular Modem with Redundant SIM Slots Antenna Connectors 2x SMA Cellular Connectors 2x RP-SMA Wi-Fi Antenna Connectors 1x SMA GPS Antenna Connector LAN Interface 2x 10/100/1000M Ethernet Power Input Wi-Fi Interface Simultaneous Dual-Band (2.4GHz / 5GHz) Wi-Fi 5, 2X2 MIMO Wi-Fi WAN1 and/or AP Power Port: 10V – 30V DC AC Adapter: AC Input 100V–240V / DC Output 12V Power over Ethernet 802.3at Power Consumption 13W (nominal), 18W (max.) SpeedFusion features Hot Failover1 / WAN Smoothing1 Dimension 5.0 x 4.2 x 1.4 inches / 125.7 x 107 x 35 mm Number of PepVPN SpeedFusion Peers 2/52 Weight 0.95 pounds / 430 grams Feature GPIO1, Ignition Sensing1 Operating Temperature -40° – 149°F / -40° – 65°C Router Throughput 300Mbps Humidity 15% – 95% (non-condensing) PepVPN Throughput (No Encryption) 80Mbps Certifications FCC, CE, RoHS Package Content PepVPN Throughput (256-bit AES) 20 Mbps / 60Mbps2 Recommended Users 1-60 1x BR1 Mini 2x LTE Antennas (ACW-235) 2x Wi-Fi Dual Band Antennas (ACW-341) 1x GPS Active Antenna (ACW-232) 1x 12V 2A 4pin Power Supply (ACW-632) Cellular Data Rate3 (Downlink/Uplink) CAT-6: 300 Mbps/50 Mbps CAT-4: 150 Mbps/50 Mbps Warranty 1-Year Limited Warranty 1 2 3 Available with a feature pack add-on license. Requires a PrimeCare subscription, complimentary for the first year. Maximum theoretical data rate. Specifications are subject to change without notice. ©Peplink.| All rights reserved. ©Peplink Pepwave. All rights reserved. ref: 2203 - v01 BR1 Mini Ordering Information Product Code Regions LTE Bands 3G Bands MAX-BR1-MINI-LTEA-W-T-PRM Primary: North America* B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41 WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8 B2, B4, B5, B12, B13, B14, B66, B71 WCDMA/HSPA+/DC-HSPA+: B2, B5 B1, B3, B5, B7, B8, B20, B38, B40, B41 WCDMA/HSPA+/DC-HSPA+: B1, B5, B8 Embedded Modem(s): 1x CAT-6 MAX-BR1-MINI-LTE-US-T-PRM Embedded Modem(s): 1x CAT-4 MAX-BR1-MINI-LTE-E-T-PRM *US Carrier Certifications (Pending): AT&T, T-Mobile, Verizon Primary: North America* *US Carrier Certifications (Pending): AT&T, T-Mobile, Verizon Primary: APAC & EMEA Embedded Modem(s): 1x CAT-4 Featured Add-on Product Code Description PRM-MAX-BR1-MINI-1Y 1-Year PrimeCare for BR1 Mini PRM-MAX-BR1-MINI-2Y 2-Year PrimeCare for BR1 Mini PRM-MAX-BR1-MINI-4Y 4-Year PrimeCare for BR1 Mini MAX-BR1-MINI-LC-FP Feature pack for BR1 Mini enables Ethernet WAN, Wi-Fi WAN, Hot Failover, WAN Smoothing, GPIO and Ignition Sensing ©Peplink | Pepwave. All rights reserved. ref: 2203 - v01
MAX-BR1-MINI-LTE-US-T-PRM 价格&库存
很抱歉,暂时无法提供与“MAX-BR1-MINI-LTE-US-T-PRM”相匹配的价格&库存,您可以联系我们找货
