07010190
07010190
    ICOMTECH
    IDS-105F-XT INDUSTRIAL SWITCH: 5
07010190 数据手册
IDS-105F Industrial Ethernet Switch perle.com/products/switches/5-port-industrial-ethernet-switch.shtml 5 port Compact DIN Rail Switch 5 port 10/100Base-TX ( RJ45 ) 4 port 10/100Base-TX ( RJ45 ) with an SC/ST fiber port Hazardous Location and Industrial Control Equipment Certification Corrosion resistant IP30 aluminum case Redundant dual power input 12/24/48 VDC, 18 to 30 VAC Overload current and reverse polarity protection Industrial operating temperature support up to -40 to 75C Perle Industrial-grade Ethernet Switches are designed to stand up to extreme temperatures, surges, vibrations, and shocks found in industrial automation, government, military, oil and gas, mining and outdoor applications. The IDS-105F 5 port Industrial Ethernet Switch provides advanced performance and enables real-time deterministic network operation. It requires no configuration and will instantly operate as soon as you power it up. The IDS-105F, which comes in a variety of models, are rugged fan-less switches that are hardened to provide superior reliability in 0 to 60°C, or harsh extended operating temperatures from -40 to 75°C. Perle has been designing industrial hardware for serial ModBus and Profinet to Ethernet conversion environments for over 35 years and have used this expertise to design the toughest Ethernet switches on the market. Don’t trust your critical communications to commercial switch products. Perle Industrial Ethernet switches give you proven assurance that your system will keep running for years to come. IDS-105F Industrial Ethernet Switch Features Rugged design for harsh environments Corrosion resistant IP30 aluminum case UL508A Industrial Control Equipment Safety certified Hazardous locations - Class1/Div2, ATEX class 1 / Zone 2 Reliable operation Fan-less, no moving parts Dual power input. Connect to separate power sources for redundancy. Reverse polarity protection Overload current protection Handles vibration and shock conditions found in industrial environments Real-time Ethernet performance Fast wire-speed , store and forward switching, non-blocking architecture Auto-sensing for speed and duplex Auto-mdi/mdix-crossover works with straight and crossover cables FCC Class B Certification The first and only DIN Rail Switch on the market that can be sold for use in areas that require especially low emissions. No frequency interference with other equipment. 1/12 Power Dual Power Input Both inputs draw power simultaneously. If one power source fails, the other live source can, acting as a backup, supply enough power to meet the operational needs of the switch. 12/24/48 VDC Nominal. (9.6 to 60 VDC) 18 to 30 VAC Power 4-Pin Removable Terminal Block. Connector Grounding screw on metal chassis Maximum Current Consumption @24 vDC 140 mA Maximum Power Consumption @24 vDC 3.4 Watts Overload Current Protection Reset-able fuse provides overload current protection Reverse polarity protection The positive and negative inputs can be reversed providing safe and simple power connectivity. Access Ports RJ45 4 or 5 shielded RJ45 ports for 10/100Base-TX up to 100 meters (328 ft) Auto-negotiation Auto-MDI/MDIX-crossover for use with either crossover over straight-through cable types Ethernet isolation 1500 V Fiber port 1 x fixed fiber port Duplex SC or ST connector Multimode 50/125 or 62.5/125 micron fiber cable Single mode 9/125 micron fiber cable Simplex (BIDI, single strand) SC connector Multimode 50/125 or 62.5/125 micron fiber cable Single mode 9/125 micron fiber cable PC and UPC type patch cords supported. 2/12 Fixed Fiber Port Specs Transmit (dBm) Fiber1 Type MMF (Duplex SC/ST) Receive (dBm) Min Max Min Max Power Budget (dB) -20.0 -12.0 -31.0 -14.0 11.0 Wavelength (nm) 1310 IEEE Core Size (um) Modal Bandwidth (MHz *Km) 100Base-FX 50 800* 5 Km 3.1 mi 62.5 500* 4 Km 2.5 mi 62.5 200 2 Km 1.2 mi Maximum Operating Distance MMF (Simplex SC/ST) -15.0 0.0 -28.0 -8.0 13.0 1310 / 1550 1550 / 1310 100Base-BX-U 100Base-BX-D 62.5 200 2 Km 1.2 mi SMF (Duplex SC/ST) -18.0 -7.0 -32.0 -3.0 14.0 1310 100Base-LX 9 ** 20 Km 12.4 mi SMF (Simplex SC) -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 1550 / 1310 100Base-BX-U 100Base-BX-D 9 ** 20 Km 12.4 mi SMF (Duplex SC/ST) -5.0 0.0 -34.0 -3.0 29.0 1310 100Base-EX 9 ** 40 Km 24.9 mi SMF (Simplex SC) -8.0 -3.0 -33.0 -3.0 18.0 1310 / 1550 1550 / 1310 100Base-BX-U 100Base-BX-D 9 ** 40 Km 24.9 mi SMF (Duplex SC/ST) -5.0 0.0 -34.0 -3.0 29.0 1550 100Base-ZX 9 ** 80 Km 4.79 mi SMF (Duplex SC/ST) 0.0 5.0 -35.0 -3.0 35.0 1550 100Base-ZX 9 ** 120 Km 74.6 mi * 1db/km multimode fiber cable ** as per ITU-T G.652 SMF specifications Switch Properties Standards IEEE 802.3 for 10Base-T IEEE 802.3u for 100Base-TX and 100Base-FX IEEE 802.3x for Flow Control Processing Type Store and Forward, non-blocking architecture MAC Address Table Size 1024 Packet Buffer Memory 512 Kbit Indicators P1 This green LED is turned on when power is applied to the power #1 input P2 This green LED is turned on when power is applied to the power #2 input RJ45 Ethernet These integrated colored LEDs indicate link, activity and speed for each port. Fiber Link Fiber link LED indicates Link and Data Activity Environmental Specifications 3/12 Operating Temperature Ranges Standard temperature models : 0° C to 60° C (32° F to 140° F). Industrial extended temperature models : -40° C to 75° C (-40 F to 167° F) Storage Temperature Range Minimum range of -25° C to 70° C (-13° F to 158° F). -40 C to 85 C (-40 F to 185 F) for industrial extended temperature models Operating Humidity Range 5% to 90% non-condensing Storage Humidity Range 5% to 95% non-condensing Operating Altitude Up to 3,048 meters (10,000 feet) Chassis Aluminum with an IP30 ingress protection rating Din Rail Mountable DIN Rail attachment included. Mounts to standard 35 mm DIN rail in accordance with DIN EN 60175. Removable to accommodate optional Panel/Wall mount kit Maximum Heat Output 11.6 BTU/Hr MTBF 913,428 hours (without fiber module) 717,100 hours (with fiber module) MTBF Calculation model based on MIL-HDBK-217-FN2 @ 30 °C Product Weight and Dimensions Weight 0.19 kg, 0.3 lbs Dimensions 30 x 115 x 70 mm, 1.18 x 4.52 x 2.76 inches Packaging Shipping Weight 0.34 kg, 0.8 lbs Shipping Dimensions 170 x 260 x 70 mm, 6.69 x 10.24 x 2.76 inches Contents Shipped Industrial Ethernet Switch with DIN Rail attachment Terminal block Installation guide Standards and Certifications 4/12 Safety IEC 62368-1 (ed 2) EN 62368-1:2014 UL 60950-1 CSA C22.2 No. 60950-1 IEC 60950-1:2005+A1:2009 and EN 60950-1:2006+A11:2009+A1:2010+A12:2011 CE Mark UL508 (Industrial) EMC Emissions FCC 47 Part 15 Class B ICES-0003 CISPR 22:2008/EN55022:2010 (Class B) EN61000-6-4 EMC Immunity CISPR 24:2010/EN 55024:2010 IEC/EN 61000-4-2 (ESD) : Contact discharge +/- 6kV, Air Discharge +/- 8kV IEC/EN 61000-4-3 (RS) : 80 MHz to 2.7 Ghz ; 10V/m, 800 MHz to 1000 MHz; 20V/m IEC/EN 61000-4-4 (EFT) : DC power line +/- 2 kV, Data Line +/- 2kV IEC/EN 61000-4-5 (Surge) : DC power line, Line/Line +/- 1kV, Line/Earth +/- 2kV, Data Line line/earth +/- 1kV IEC/EN 61000-4-6 (CS) : 150kHz to 80 MHz; 10V IEC/EN 61000-4-8 (Magnetic Field): 30 A/m IEC/EN 61000-6-2 (General Immunity in Industrial Environments) Industrial Safety UL508 (Safety standard for Industrial Control Equipment) CSA C22.2 No. 142 Hazardous Locations (Hazloc) ANSI/ISA 12.12.01, Class I Division 2 Groups A-D (formerly known as UL 1604) CSA C22.2 No. 213 ATEX Class I Zone 2, EN60079-0,15 Laser Safety EN 60825-1:2007 Fiber optic transmitters on this device meet Class 1 Laser safety requirements per IEC60825 FDA/CDRH standards and comply with 21CFR1040.10 and 21CFR1040.11. Environmental Reach, RoHS and WEEE Compliant Other ECCN: 5A991 HTSUS Number: 8517.62.0020 5 year warranty IDS-105F with Standard DIN Rail 5/12 6/12 IDS-105F with Optional Wall/Panel Mount Brackets IDS-105F Industrial Switch Diagram 7/12 Single Mode / Single Strand ( WDM ) Fiber Connecting devices over a single fiber strand ( also referred to as “Bi-Directional” BiDi or Simplex) To reduce costs, or where there are limits on available fiber, Wavelength-Division Multiplexing (WDM) technology may be utilized. WDM uses separate transmit and receive frequencies to communicate on a single fiber strand. WDM technology relies on the fact that optical fibers can carry many wavelengths of light simultaneously without interaction between each wavelength. Thus, a single fiber can carry many separate wavelength signals or channels simultaneously. WDM systems are divided into different wavelength patterns, conventional/coarse (CWDM) and dense (DWDM). When Single Strand fiber is used, you will need an “Up” side and a “Down” side when interconnecting fiber devices. Perle offers a wide variety of Single Fiber (“Up/Down”) Ethernet Switches and Media Converters for use with single strand of fiber. Select a Model to obtain a Part Number – IDS-105F Std = Standard Temperature models : 0° C to 60° C (32° F to 140° F). Ind = Industrial Extended Temperature Models : -40° C to 75° C (-40 F to 167° F) Models with 5 x 10/100Base-TX (RJ45) Connectors Model Temp IDS-105F Std IDS-105F-XT Ind 8/12 Models with 4 x 10/100Base-TX (RJ45) Connectors Choose your Fiber Connection from the table below 100Base-X Duplex Fiber Transmit (dBm) Model Temp Fiber Connector Receive (dBm) Min Max Min Max Power Budget (dB) Wavelength (nm) Fiber Type Operating Distance IDS105FM2SC2 Std 1 x Duplex SC -20.0 -12.0 -31.0 -14.0 11.0* 1310 MMF 5 km* (3.1 mi) IDS105FM2SC2XT Ind 1 x Duplex SC -20.0 -12.0 -31.0 -14.0 11.0* 1310 MMF 5 km* (3.1 mi) IDS105FM2ST2 Std 1 x Duplex ST -20.0 -12.0 -31.0 -14.0 11.0* 1310 MMF 5 km* (3.1 mi) IDS105FM2ST2XT Ind 1 x Duplex ST -20.0 -12.0 -30.0 -14.0 10.0* 1310 MMF 5 km* (3.1 mi) IDS105FS2SC20 Std 1 x Duplex SC -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS105FS2SC20XT Ind 1 x Duplex SC -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS105FS2ST20 Std 1 x Duplex ST -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS105FS2ST20XT Ind 1 x Duplex ST -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS105FS2SC40 Std 1 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) 9/12 IDS105FS2SC40XT Ind 1 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS105FS2ST40 Std 1 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS105FS2ST40XT Ind 1 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS105FS2SC80 Std 1 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1550 SMF 80 km (50 mi) IDS105FS2ST80 Std 1 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1550 SMF 80 km (50 mi) IDS105FS2SC120 Std 1 x Duplex SC 0.0 5.0 -35.0 -3.0 35.0 1550 SMF 120 km (75 mi) IDS105FS2ST120 Std 1 x Duplex ST 0.0 5.0 -35.0 -3.0 35.0 1550 SMF 120 km (75 mi) * 1db/km multimode 50/125 micron fiber cable Single Fiber (Simplex / BiDi) Models Recommended use in pairs Models with 4 x 10/100Base-TX (RJ45) Connectors Choose your Fiber Connection from the table below 100Base-X Simplex (BiDi) Fiber Transmit (dBm) Model Temp Fiber Connector Receive (dBm) Min Max Min Max Power Budget (dB) Wavelength (nm) Fiber Type Operating Distance IDS-105FM1SC2U Std 1x Simplex SC -15.0 0.0 -28.0 -8.0 13.0 1310 / 1550 MMF 2 km (1.2 mi) IDS-105FM1SC2D Std 1x Simplex SC -15.0 0.0 -28.0 -8.0 13.0 1550 / 1310 MMF 2 km (1.2 mi) 10/12 IDS-105FM1ST2U Std 1x Simplex ST -15.0 0.0 -28.0 -8.0 13.0 1310 / 1550 MMF 2 km (1.2 mi) IDS-105FM1ST2D Std 1x Simplex ST -15.0 0.0 -28.0 -8.0 13.0 1550 / 1310 MMF 2 km (1.2 mi) IDS-105FS1ST20U Std 1x Simplex ST -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) IDS-105FS1ST20D Std 1x Simplex ST -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) IDS-105FS1SC20U Std 1x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) IDS-105FS1SC20D Std 1x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) IDS-105FS1SC20UXT Ind 1x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) IDS-105FS1SC20DXT Ind 1x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) IDS-105FS1SC40U Std 1x Simplex SC -8.0 -3.0 -33.0 -3.0 25.0 1310 / 1550 SMF 40 km (25 mi) IDS-105FS1SC40D Std 1x Simplex SC -8.0 -3.0 -33.0 -3.0 25.0 1550 / 1310 SMF 40 km (25 mi) Industrial Ethernet Switch Accessories Panel Mount kit PM3 Brackets for attaching 30 to 45 mm wide Perle IDS industrial switches inside a control panel or to a wall for wall. Rack Mount Kit RM4U Bracket for mounting one or more Perle DIN Rail switches in a standard 19” rack. Occupies “4U” of vertical rack space. 275 mm (10 inches) deep UNOPS/1AC/24DC/60W DIN-Rail Power Supply UNO-PS/1AC/24DC/60W DIN-Rail Power Supply: 24 VDC, 60 Watt with universal 85 to 264 VAC, -25 to 70°C extended operating temperature. Power Supply Specifications. UNOPS/1AC/24DC/150W Power Supply UNO-PS/1AC/24DC/150W Power Supply - DIN-Rail 24 VDC , 150 Watt power supply with universal 85 to 264 VAC, -25 to 70°C extended operating temperature. Power Supply Specifications. 11/12 Copyright © 1996 - 2021 Perle. All Rights Reserved 12/12
07010190 价格&库存
很抱歉,暂时无法提供与“07010190”相匹配的价格&库存,您可以联系我们找货
