07009960
07009960
    ICOMTECH
    IDS-108FPP-DM1ST2U INDUSTRIAL PO
07009960 数据手册
IDS-108FPP – Industrial PoE Switch perle.com/products/switches/8-port-industrial-poe-switch.shtml 8 to 10 port Compact DIN Rail PoE Switch 8 port 10/100Base-TX ( RJ45 ) 8 port 10/100Base-TX ( RJ45 ) plus 1 or 2 SC/ST fiber ports 4 PoE/PoE+ PSE capable ports, fully compliant to IEEE 802.3af/at Hazardous Location and Industrial Control Equipment Certification Corrosion resistant IP30 aluminum case Redundant dual power input 24/48 VDC Overload current and reverse polarity protection Industrial operating temperature support up to -40 to 75C Perle Industrial-grade PoE Switches are designed to stand up to extreme temperatures, surges, vibrations, and shocks found in industrial automation, government, military, oil and gas, mining and outdoor applications. In addition, these PoE Switches are classified as Power Sourcing Equipment (PSE). While using standard UTP cables that carry Ethernet data, the IDS-108FPP have 4 ports that also provide up to 30 watts of power to Powered Devices (PDs) such as wireless access points, Voice over IP phones and IP cameras. Learn more about PoE. The IDS-108FPP is an 8 to 10 port Industrial Ethernet Switch with Power over Ethernet providing advanced performance enabling real-time deterministic network operation. It requires no configuration and will operate instantly as soon as you power it up. IDS-108FPP are rugged fan-less switches that are hardened to provide superior reliability in 0 to 60°C, or harsh extended operating temperatures from -40 to 75°C. They come in a variety of models with 8 copper ports, 8 copper ports plus 1 fiber port or 8 copper ports plus 2 fiber ports. Perle has been designing industrial hardware for serial ModBus and Profinet to Ethernet conversion environments for over 35 years and have used this expertise to design the toughest Ethernet switches on the market. Don’t trust your critical communications to commercial switch products. Perle Industrial Ethernet switches give you proven assurance that your system will keep running for years to come. IDS-108FPP Industrial PoE Switch Features Rugged design for harsh environments Corrosion resistant IP30 aluminum case UL508A Industrial Control Equipment Safety certified Hazardous locations - Class1/Div2, ATEX Class1/Zone2 1/16 Reliable operation Fan-less, no moving parts Dual power input. Connect to separate power sources for redundancy. Reverse polarity protection Overload current protection Handles vibration and shock conditions found in industrial environments PoE and PoE+ ( on 4 ports ) Up to 30 Watts per port driving up to four class 4 ( IEEE 802.3at Type 2 ) PDs Input Voltage Booster Voltage boost technology supports 24V power sources ensuring that a full and proper PSE voltage is provided across all PoE ports Real-time Ethernet performance Fast wire-speed , store and forward switching, non-blocking architecture Auto-sensing for speed and duplex Auto-mdi/mdix-crossover works with straight and crossover cables Power Dual Power Input Both inputs draw power simultaneously. If one power source fails, the other live source can, acting as a backup, supply enough power to meet the operational needs of the switch. Flexible input voltage range : 24/48 VDC Nominal. (18 to 57 VDC) Input Voltage Booster Voltage boost technology supports 24V industrial power sources ensuring that a full and proper PSE voltage is available across all PoE ports Power Connector 4-Pin Removable Terminal Block. Grounding screw on metal chassis Maximum Current Consumption @24 vDC .29 Amps (No PoE PDs attached) 5.6 Amps (4 x PoE+) Maximum Power Consumption @24 vDC 7 Watts (No PoE PDs attached) 134 Watts (4 x 30 Watts PoE+) Overload Current Protection Reset-able fuse provides overload current protection Reverse polarity protection Protection is provided should inputs be reversed Access Ports 2/16 RJ45 8 shielded RJ45 ports for 10/100Base-TX up to 100 meters (328 ft). 4 of these ports are PoE PSE capable Auto-negotiation Auto-MDI/MDIX-crossover for use with either crossover over straight-through cable types Ethernet isolation 1500 V PoE 4 PoE/PoE+ ports Up to 30 Watts per port (@ switch RJ45) driving up to four class 4 (IEEE 802.3at Type 2) PDs Fiber port 1 or 2 fixed fiber port models Duplex SC or ST connector Multimode 50/125 or 62.5/125 micron fiber cable Single mode 9/125 micron fiber cable Simplex (BIDI, single strand) SC connector Multimode 50/125 or 62.5/125 micron fiber cable Single mode 9/125 micron fiber cable PC and UPC type patch cords supported. Fixed Fiber Port Specs Transmit (dBm) Fiber1 Type MMF (Duplex SC/ST) Receive (dBm) Min Max Min Max Power Budget (dB) Wavelength (nm) IEEE Core Size (um) Modal Bandwidth (MHz *Km) -20.0 -12.0 -31.0 -14.0 11.0 1310 100Base-FX 50 800* 5 Km 3.1 mi 62.5 500* 4 Km 2.5 mi 62.5 200 2 Km 1.2 mi Maximum Operating Distance MMF (Simplex SC) -15.0 0.0 -28.0 -8.0 13.0 1310 / 1550 1550 / 1310 100Base-BX-U 100Base-BX-D 62.5 200 2 Km 1.2 mi SMF (Duplex SC/ST) -18.0 -7.0 -32.0 -3.0 14.0 1310 100Base-LX 9 ** 20 Km 12.4 mi SMF (Simplex SC) -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 1550 / 1310 100Base-BX-U 100Base-BX-D 9 ** 20 Km 12.4 mi SMF (Duplex SC/ST) -5.0 -0.0 -34.0 -3.0 29.0 1310 100Base-EX 9 ** 40 Km 24.9 mi SMF (Simplex SC) -8.0 -3.0 -33.0 -3.0 18.0 1310 / 1550 1550 / 1310 100Base-BX-U 100Base-BX-D 9 ** 40 Km 24.9 mi SMF (Duplex SC/ST) -5.0 0.0 -34.0 -3.0 29.0 1550 100Base-ZX 9 ** 80 Km 49.7 mi SMF (Duplex SC/ST) 0.0 5.0 -35.0 -3.0 35.0 1550 100Base-ZX 9 ** 120 Km 74.6 mi * 1db/km multimode fiber cable ** as per ITU-T G.652 SMF specifications Switch Properties 3/16 Standards IEEE 802.3 for 10Base-T IEEE 802.3u for 100Base-TX and 100Base-FX IEEE 802.3x for Flow Control IEEE 802.3af Power Over Ethernet IEEE 802.3at Power Over Ethernet Processing Type Store and Forward, non-blocking architecture MAC Address Table Size 8K Packet Buffer Memory 1 Mbit Indicators P1 This green LED is turned on when power is applied to the power #1 input P2 This green LED is turned on when power is applied to the power #2 input RJ45 Ethernet These integrated colored LEDs indicate link, activity and speed for each port. Fiber Link Fiber link LED indicates Link and Data Activity Environmental Specifications Operating Temperature Ranges Standard temperature models : 0° C to 60° C (32° F to 140° F). Industrial extended temperature models : -40° C to 75° C (-40 F to 167° F) Storage Temperature Range Minimum range of -25° C to 70° C (-13° F to 158° F). -40 C to 85 C (-40 F to 185 F) for industrial extended temperature models Operating Humidity Range 5% to 90% non-condensing Storage Humidity Range 5% to 95% non-condensing Operating Altitude Up to 3,048 meters (10,000 feet) Chassis Aluminum with an IP30 ingress protection rating Din Rail Mountable DIN Rail attachment included. Mounts to standard 35 mm DIN rail in accordance with DIN EN 60175. Removable to accommodate optional Panel/Wall mount kit Maximum Heat Output 24 BTU/Hr 4/16 MTBF 606,418 hours (without fiber module) 350,726 hours (with 1 fixed fiber module) 316,656 hours (with 2 fixed fiver modules) MTBF Calculation model based on MIL-HDBK-217-FN2 @ 30 °C Product Weight and Dimensions Weight 0.37 Kg, 0.82 lbs Dimensions 111 x 138 x 47.4 mm, 4.37 x 5.43 x 1.87 inches Packaging Shipping Weight 0.52 Kg, 1.15 lbs Shipping Dimensions 170 x 260 x 70 mm, 6.69 x 10.24 x 2.76 inches Contents Shipped Industrial Ethernet Switch with DIN Rail attachment Terminal block Installation guide Standards and Certifications Safety IEC 62368-1 (ed 2) EN 62368-1:2014 UL 60950-1 CSA C22.2 No. 60950-1 IEC 60950-1:2005+A1:2009 and EN 60950-1:2006+A11:2009+A1:2010+A12:2011 CE Mark UL508 (Industrial) EMC Emissions FCC 47 Part 15 Class A CISPR 22:2008/EN55022:2010 (Class A) EN61000-6-4 EMC and Immunity CISPR 24:2010/EN 55024:2010 IEC/EN 61000-4-2 (ESD) : Contact discharge +/- 4kV, Air Discharge +/- 8kV IEC/EN 61000-4-3 (RS) : 10V/m IEC/EN 61000-4-4 (EFT) : DC power line +/- 2 kV, Data Line +/- 1kV IEC/EN 61000-4-5 (Surge) : DC power line, Line/Line +/- 0.5kV, Line/Earth +/0.5kV, Data Line line/earth +/- 1kV IEC/EN 61000-4-6 (CS) : 150kHz to 80 MHz; 10V IEC/EN 61000-4-8 : 30A/m IEC/EN 61000-6-2 (General Immunity in Industrial Environments) Industrial Safety UL508 (Safety standard for Industrial Control Equipment) CSA C22.2 No. 142 Hazardous Locations (Hazloc) ANSI/ISA 12.12.01, Class I Division 2 Groups A-D (formerly known as UL 1604) CSA C22.2 No. 213 ATEX Class I Zone 2, EN60079-0, 15 5/16 Laser Safety EN 60825-1:2007 Fiber optic transmitters on this device meet Class 1 Laser safety requirements per IEC-60825 FDA/CDRH standards and comply with 21CFR1040.10 and 21CFR1040.11. Environmental Reach, RoHS and WEEE Compliant Other ECCN: 5A991 HTSUS Number: 8517.62.0020 5 year warranty IDS-108FPP with Standard DIN Rail 6/16 7/16 IDS-108F with Optional Wall/Panel Mount Brackets 8/16 IDS-108FPP Industrial Switch Power over Ethernet ( PoE )Diagram Single Mode / Single Strand ( WDM ) Fiber 9/16 Connecting devices over a single fiber strand ( also referred to as “Bi-Directional” BiDi or Simplex) To reduce costs, or where there are limits on available fiber, Wavelength-Division Multiplexing (WDM) technology may be utilized. WDM uses separate transmit and receive frequencies to communicate on a single fiber strand. WDM technology relies on the fact that optical fibers can carry many wavelengths of light simultaneously without interaction between each wavelength. Thus, a single fiber can carry many separate wavelength signals or channels simultaneously. WDM systems are divided into different wavelength patterns, conventional/coarse (CWDM) and dense (DWDM). When Single Strand fiber is used, you will need an “Up” side and a “Down” side when interconnecting fiber devices. Perle offers a wide variety of Single Fiber (“Up/Down”) Ethernet Switches and Media Converters for use with single strand of fiber. Select a Model to obtain a Part Number – IDS-108FPP Operating Temperature (Std) = 0° C to 60° C (32° F to 140° F) Models with 8 x 10/100/1000Base-T (RJ45) Connectors Choose your Fiber Connections from the table below 100Base-X Duplex Fiber Model Fiber Connector Transmit (dBm) Receive (dBm) Min Min Max Max Power Budget (dB) Wavelength (nm) Fiber Type Operating Distance IDS108FPP NO Fiber Connection IDS108FPPM2SC2 1 x Duplex SC -20.0 -12.0 -31.0 -14.0 11.0* 1310 MMF 5 km* (3.1 mi) IDS108FPPM2ST2 1 x Duplex ST -20.0 -12.0 -31.0 -14.0 11.0* 1310 MMF 5 km* (3.1 mi) IDS108FPPS2SC20 1 x Duplex SC -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) 10/16 IDS108FPPS2ST20 1 x Duplex ST -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS108FPPS2SC40 1 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS108FPPS2ST40 1 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS108FPPS2SC80 1 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1550 SMF 80 km (50 mi) IDS108FPPS2ST80 1 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1550 SMF 80 km (50 mi) IDS108FPPS2SC120 1 x Duplex SC 0.0 5.0 -35.0 -3.0 35.0 1550 SMF 120 km (75 mi) IDS108FPPS2ST120 1 x Duplex ST 0.0 5.0 -35.0 -3.0 35.0 1550 SMF 120 km (75 mi) IDS108FPPDM2SC2 2 x Duplex SC -20.0 -12.0 -31.0 14.0 11.0* 1310 MMF 2 km (1.2 mi) IDS108FPPDM2ST2 2 x Duplex ST -20.0 -12.0 -31.0 14.0 11.0* 1310 MMF 2 km (1.2 mi) IDS108FPPDS2SC20 2 x Duplex SC -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS108FPPDS2ST20 2 x Duplex ST -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS108FPPDS2SC40 2 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS108FPPDS2ST40 2 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS108FPPDS2SC80 2 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1550 SMF 80 km (50 mi) 11/16 IDS108FPPDS2ST80 2 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1550 SMF 80 km (50 mi) IDS108FPPDS2SC120 2 x Duplex SC 0.0 5.0 -35.0 -3.0 35.0 1550 SMF 120 km (75 mi) IDS108FPPDS2ST120 2 x Duplex ST 0.0 5.0 -35.0 -3.0 35.0 1550 SMF 120 km (75 mi) * 1db/km multimode 50/125 micron fiber cable Single Fiber (Simplex / BiDi) Models Recommended use in pairs Models with 8 x 10/100/1000Base-T (RJ45) Connectors Choose your Fiber Connections from the table below 100Base-X Simplex (BiDi) Fiber Transmit (dBm) Receive (dBm) Min Max Min Max Power Budget (dB) Wavelength (nm) TX / RX Fiber Type Operating Distance Model Fiber Connector IDS108FPPM1SC2U 1x Simplex SC -15.0 0.0 -28.0 -8.0 13.0 1310 / 1550 MMF 2 km (1.2 mi) IDS108FPPM1SC2D 1x Simplex SC -15.0 0.0 -28.0 -8.0 13.0 1550 / 1310 MMF 2 km (1.2 mi) IDS108FPPM1ST2U 1x Simplex ST -15.0 0.0 -28.0 -8.0 13.0 1310 / 1550 MMF 5 km (3.1 mi) IDS108FPPM1ST2D 1x Simplex ST -15.0 0.0 -28.0 -8.0 13.0 1550 / 1310 MMF 5 km (3.1 mi) IDS108FPPDM1ST2U 2x Simplex ST -15.0 0.0 -28.0 -8.0 13.0 1310 / 1550 MMF 5 km (3.1 mi) IDS108FPPDM1ST2D 2x Simplex ST -15.0 0.0 -28.0 -8.0 13.0 1550 / 1310 MMF 5 km (3.1 mi) IDS108FPPS1ST20U 1x Simplex ST -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) 12/16 IDS108FPPS1ST20D 1x Simplex ST -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) IDS108FPPDS1ST20U 2x Simplex ST -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) IDS108FPPDS1ST20D 2x Simplex ST -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) IDS108FPPS1SC20U 1x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) IDS108FPPS1SC20D 1x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) IDS108FPPS1SC40U 1x Simplex SC -8.0 -3.0 -33.0 -3.0 25.0 1310 / 1550 SMF 40 km (25 mi) IDS108FPPS1SC40D 1x Simplex SC -8.0 -3.0 -33.0 -3.0 25.0 1550 / 1310 SMF 40 km (25 mi) IDS108FPPDM1SC2U 2x Simplex SC -15.0 0.0 -28.0 -8.0 13.0 1310 / 1550 MMF 2 km (1.2 mi) IDS108FPPDM1SC2D 2x Simplex SC -15.0 0.0 -28.0 -8.0 13.0 1550 / 1310 MMF 2 km (1.2 mi) IDS108FPPDS1SC20U 2x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) IDS108FPPDS1SC20D 2x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) IDS108FPPDS1SC40U 2x Simplex SC -8.0 -3.0 -33.0 -3.0 25.0 1310 / 1550 SMF 40 km (25 mi) IDS108FPPDS1SC40D 2x Simplex SC -8.0 -3.0 -33.0 -3.0 25.0 1550 / 1310 SMF 40 km (25 mi) Industrial Ethernet Switch Accessories 13/16 Panel Mount kit PM3 Brackets for attaching 30 to 40mm wide Perle IDS industrial switches inside a control panel or to a wall. Rack Mount Kit RM4U Bracket for mounting one or more Perle DIN Rail switches in a standard 19” rack. Occupies “4U” of vertical rack space. 275 mm (10 inches) deep DIN Rail 48V Power Supply IDPS-48-240-XT - DIN-Rail 48 VDC , 240Watt power supply with universal 85 to 264 VAC or 120-370 VDC input , -10 to 70°C extended operating temperature. Power Supply Specifications. TRIOPS/1AC/48DC/10 Power Supply TRIO-PS/1AC/48DC/10 Power Supply - DIN-Rail 48 VDC , 480 Watt power supply with universal 85 to 264 VAC, 30 to 56V DC output range adjustable, -25 to 70°C extended operating temperature. Power Supply Specifications. UNOPS/1AC/24DC/150W Power Supply UNO-PS/1AC/24DC/150W Power Supply - DIN-Rail 24 VDC , 150 Watt power supply with universal 85 to 264 VAC, -25 to 70°C extended operating temperature. Power Supply Specifications. Select a Model to obtain a Part Number – IDS-108FPP Operating Temperature (Ind) = -40° C to 75° C (-40 F to 167° F) Models with 8 x 10/100/1000Base-T (RJ45) Connectors Choose your Fiber Connections from the table below 100Base-X Duplex Fiber Model Fiber Connector Transmit (dBm) Receive (dBm) Min Min Max Max Power Budget (dB) Wavelength (nm) Fiber Type Operating Distance IDS108FPPXT NO Fiber Connection IDS108FPPM2SC2XT 1 x Duplex SC -20.0 -12.0 -31.0 -14.0 11.0* 1310 MMF 5 km* (3.1 mi) IDS108FPPM2ST2XT 1 x Duplex ST -20.0 -12.0 -30.0 -14.0 10.0* 1310 MMF 5 km* (3.1 mi) IDS108FPPS2SC20XT 1 x Duplex SC -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) 14/16 IDS108FPPS2ST20XT 1 x Duplex ST -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS108FPPS2SC40XT 1 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS108FPPS2ST40XT 1 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS108FPPDM2SC2XT 2 x Duplex SC -20.0 -12.0 -31.0 14.0 11.0* 1310 MMF 2 km (1.2 mi) IDS108FPPDM2ST2XT 2 x Duplex ST -20.0 -12.0 -30.0 14.0 10.0* 1310 MMF 2 km (1.2 mi) IDS108FPPDS2SC20XT 2 x Duplex SC -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS108FPPDS2ST20XT 2 x Duplex ST -18.0 -7.0 -32.0 -3.0 14.0 1310 SMF 20 km (12.4 mi) IDS108FPPDS2SC40XT 2 x Duplex SC -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) IDS108FPPDS2ST40XT 2 x Duplex ST -5.0 0.0 -34.0 -3.0 29.0 1310 SMF 40 km (25 mi) * 1db/km multimode 50/125 micron fiber cable Single Fiber (Simplex / BiDi) Models Recommended use in pairs Models with 8 x 10/100/1000Base-T (RJ45) Connectors Model Choose your Fiber Connections from the table below 100Base-X Simplex (BiDi) Fiber 15/16 Fiber Connector Transmit (dBm) Receive (dBm) Min Max Min Max Power Budget (dB) Wavelength (nm) TX / RX Fiber Type Operating Distance IDS108FPPS1SC20UXT 1x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) IDS108FPPS1SC20DXT 1x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) IDS108FPPDS1SC20UXT 2x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1310 / 1550 SMF 20 km (12.4 mi) IDS108FPPDS1SC20DXT 2x Simplex SC -14.0 -8.0 -32.0 -3.0 18.0 1550 / 1310 SMF 20 km (12.4 mi) Industrial Ethernet Switch Accessories Panel Mount kit PM3 Brackets for attaching 30 to 40mm wide Perle IDS industrial switches inside a control panel or to a wall. Rack Mount Kit RM4U Bracket for mounting one or more Perle DIN Rail switches in a standard 19” rack. Occupies “4U” of vertical rack space. 275 mm (10 inches) deep DIN Rail 48V Power Supply IDPS-48-240-XT - DIN-Rail 48 VDC , 240Watt power supply with universal 85 to 264 VAC or 120-370 VDC input , -10 to 70°C extended operating temperature. Power Supply Specifications. TRIOPS/1AC/48DC/10 Power Supply TRIO-PS/1AC/48DC/10 Power Supply - DIN-Rail 48 VDC , 480 Watt power supply with universal 85 to 264 VAC, 30 to 56V DC output range adjustable, -25 to 70°C extended operating temperature. Power Supply Specifications. UNOPS/1AC/24DC/150W Power Supply UNO-PS/1AC/24DC/150W Power Supply - DIN-Rail 24 VDC , 150 Watt power supply with universal 85 to 264 VAC, -25 to 70°C extended operating temperature. Power Supply Specifications. Copyright © 1996 - 2021 Perle. All Rights Reserved 16/16
07009960 价格&库存
很抱歉,暂时无法提供与“07009960”相匹配的价格&库存,您可以联系我们找货
