S-1132B15-U5T1G
S-1132B15-U5T1G
    ABLIC(艾普凌科)
    SOT89-5
    IC REG LINEAR 1.5V 300MA SOT89-5
S-1132B15-U5T1G 数据手册
Extract from the online catalog     VS-CAT5-F-4X2X26 AWG/100 Order No.: 1658862 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1658862   CAT5e-S/UTP cable, 4 x 2 x 26 AWG, stranded (7-wire), shielded, outer sheath: Halogen-free PUR, outside diameter 6.1 mm, RAL 5021 (water blue), cable ring 100 m   Product notes WEEE/RoHS-compliant since: 10/25/2006 Commercial data GTIN (EAN) 4 046356 166874 Note Made-to-order sales group D515 Pack 1 pcs. Customs tariff 85444290 Catalog page information Page 177 (PC-2007) http:// www.download.phoenixcontact.com Please note that the data given here has been taken from the online catalog. For comprehensive information and data, please refer to the user documentation. The General Terms and Conditions of Use apply to Internet downloads. Technical data Mechanical characteristics Number of positions 8 Shielded Yes Cable diameter 6.10 mm Cable structure 4x2xAWG26/7; S-UTP PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 1 / 4 Feb 24, 2011 VS-CAT5-F-4X2X26 AWG/100 Order No.: 1658862 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1658862 Smallest bending radius, fixed installation 50 mm (cable, fixed installation) Smallest bending radius, movable installation 95 mm (cable, flexible installation) Length of cable 100 m Ambient temperature (operation) -30 °C ... 80 °C (cable, fixed installation) -5 °C ... 60 °C (cable, flexible installation) Material data Outer sheath, material PUR External sheath, color water blue RAL 5021 Electrical characteristics Rated voltage (III/3) 125 V Transmission characteristics (category) CAT5 (IEC 11801:2002), CAT5e (TIA 568B:2001) Line characteristics Cable type Ethernet Cable structure 4x2xAWG26/7; S-UTP Conductor cross section 0.14 mm² AWG signal line 26 Conductor structure signal line 7x 0.16 mm Core diameter including insulation 1 mm External cable diameter 6.10 mm Wire colors white/blue-blue, white/orange-orange, white/green-green, white/ brown-brown External sheath, color water blue RAL 5021 Insulation resistance ≥ 5 GΩ*km Conductor resistance ≤ 284 Ω/km Transmission characteristics (category) CAT5 (IEC 11801:2002), CAT5e (TIA 568B:2001) Working capacitance 48 nF (At 800 Hz) Wave impedance 100 Ω ±15% (At 1 to 100 MHz) Nominal voltage, conductor 125 V Test voltage Core/Core 1000 V Test voltage Core/Shield 500 V Twisted pairs 2 cores to the pair Overall twist 4 pairs for core Shielding Plastic-coated aluminum foil, tinned copper braided shield Optical shield covering 85 % PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 2 / 4 Feb 24, 2011 VS-CAT5-F-4X2X26 AWG/100 Order No.: 1658862 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1658862 Outer sheath, material PUR Conductor material Bare Cu litz wires Smallest bending radius, fixed installation 50 mm (cable, fixed installation) Smallest bending radius, movable installation 95 mm (cable, flexible installation) Accessories Item Designation Description VS-CABLE-STRIP-VARIO Stripping tool, for the multi-level stripping of shielded cables Tools 1657407 PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 3 / 4 Feb 24, 2011 VS-CAT5-F-4X2X26 AWG/100 Order No.: 1658862 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1658862 Address PHOENIX CONTACT Deutschland GmbH Flachsmarktstr. 8 32825 Blomberg,Germany Phone +49 5235 3 12000 Fax +49 5235 3 41200 http://www.phoenixcontact.de © 2011 Phoenix Contact Technical modifications reserved; PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 4 / 4 Feb 24, 2011
S-1132B15-U5T1G 价格&库存
很抱歉,暂时无法提供与“S-1132B15-U5T1G”相匹配的价格&库存,您可以联系我们找货
