PIS-1348
PIS-1348
    PISUPPLY
    DS2482-100 1-Wire 转 I2C 接口 Raspberry Pi 平台评估扩展板
PIS-1348 数据手册
  1 Wire Pi Plus Features  1‐Wire® to I2C host interface with ESD protection diode.  Stackable with other Raspberry Pi accessory boards.  Buffered 5V I2C port.  External 5V power input for 1‐Wire® interface.  2C address selection via solder jumpers. The 1 Wire Pi Plus from AB Electronics UK is a communication board supporting the 1‐Wire® protocol designed for use on the Raspberry Pi. A 5V buffered I2C port is also provided on the board. The 1 Wire Pi Plus can be securely fitted to your Raspberry Pi using our mounting kit pack. The 1‐Wire® port on the 1 Wire Pi Plus is based around a DS2482‐100 I2C to 1‐ Wire® bridge device. The DS2482‐100 provides bi‐directional protocol conversion between the I2C port on the Raspberry Pi and any attached 1‐Wire® slave devices. An ESD Protection Diode is used to protect the 1 Wire Pi Plus and Raspberry Pi from electrostatic spikes on the 1‐Wire® port. Connections to the 1‐Wire® port can be made through the RJ‐12 socket or the solder points on the PCB. We have a knowledge base articlefor configuring and using the 1‐Wire® port on your Raspberry Pi. The 1 Wire Pi Plus is powered through the host Raspberry Pi using the GPIO port and extended pins on the GPIO connector allow you to stack the 1 Wire Pi Plus along with other expansion boards.                                                            https://uk.pi‐supply.com/products/1‐wire‐pi‐plus/3‐20‐19
PIS-1348
1. 物料型号:1 Wire Pi Plus 2. 器件简介:1 Wire Pi Plus 是由 AB Electronics UK 设计的通信板,支持 1-Wire® 协议,用于 Raspberry Pi。它提供了一个 5V 缓冲的 I2C 端口,并且可以与其他 Raspberry Pi 附件板堆叠。 3. 引脚分配: - AD1:1-Wire® 数据输入 - AD0:1-Wire® 数据输出 - SDA:I2C 数据线 - SCL:I2C 时钟线 - OW:1-Wire® 端口 - RT:1-Wire® 电阻终止 - GND:地 - 5V:电源 4. 参数特性: - 1-Wire® 到 I2C 主机接口,具有 ESD 保护二极管 - 通过焊接跳线选择 I2C 地址 - 外部 5V 电源输入,用于 1-Wire® 接口 5. 功能详解: - 1-Wire® 端口基于 DS2482-100 I2C 到 1-Wire® 桥接设备,提供双向协议转换 - ESD 保护二极管用于保护 1 Wire Pi Plus 和 Raspberry Pi 免受 1-Wire® 端口上的静电冲击 - 1-Wire® 端口连接可以通过 RJ-12 插座或 PCB 上的焊接点进行 6. 应用信息: - 1 Wire Pi Plus 通过 Raspberry Pi 的 GPIO 端口供电 - 扩展的 GPIO 连接器引脚允许你将 1 Wire Pi Plus 与其他扩展板一起堆叠 7. 封装信息: - 1 Wire Pi Plus 可以安全地安装在 Raspberry Pi 上,使用提供的安装套件包
PIS-1348 价格&库存
很抱歉,暂时无法提供与“PIS-1348”相匹配的价格&库存,您可以联系我们找货
PIS-1348
  • 1+235.770021+30.50046
库存:33
