PIS-0787
PIS-0787
    PISUPPLY
    1600 MAH SMARTPHONE BATTERY - CO
PIS-0787 数据手册
    1600 mAh Smartphone Battery ‐ Compatible with PiJuice 1600mAh Lithium Ion battery that can be used with the PiJuice HAT module. The PiJuice HAT comes with a 1820mAh as standard, so this 1600mAh is a good replacement battery. The battery contains short circuit & overcharge protection Check out the PiJuice Battery Discharge Calculator to work out roughly how long your battery will last.  Capacity: 1600mAh/5.92Wh  Volts: 3.7  Type: Li‐ion                               https://uk.pi‐supply.com/products/1600‐mah‐smartphone‐battery‐compatible‐with‐pijuice 6‐27‐18
PIS-0787 价格&库存
很抱歉,暂时无法提供与“PIS-0787”相匹配的价格&库存,您可以联系我们找货
