PIS-0786
PIS-0786
    PISUPPLY
    2300 MAH BATTERY - COMPATIBLE WI
PIS-0786 数据手册
    2300 mAh Battery ‐ Compatible with PiJuice 2300 mAh Lithium Ion battery that can be used with the PiJuice HAT module. The PiJuice HAT comes with a 1820mAh as standard, so this 2300mAh will give you a little extra boost! The battery contains short circuit & overcharge protection Check out the PiJuice Battery Discharge Calculator to work out roughly how long your battery will last.  Capacity: 2300mAh/8.51Wh  Dimension: 49.50 x 45.00 x 11.00mm  Volts: 3.7  Type: Li‐ion                              https://uk.pi‐supply.com/products/2300‐mah‐battery‐compatible‐with‐pijuice 6‐27‐18
PIS-0786 价格&库存
很抱歉,暂时无法提供与“PIS-0786”相匹配的价格&库存,您可以联系我们找货
