PIS-1350
PIS-1350
    PISUPPLY
    MCP3202,MCP4822 ADC,DAC 数据采集 Raspberry Pi Zero 平台评估扩展板
PIS-1350 数据手册
  ADC‐DAC Pi Zero The ADCDAC Pi Zero is compatible with all Raspberry Pi models from the A+ and B+ onwards. The ADC‐DAC Pi Zero is a 2 channel 12 bit analogue to digital converter and 2 channel 12 bit digital to analogue converter designed to work with the Raspberry Pi. Designed for the same footprint as the Raspberry Pi Zero the ADC‐DAC Pi Zero is also compatible with full size Raspberry Pi models. The ADC‐DAC Pi Zero is based on the Microchip MCP3202 A/D converter containing 2 analogue inputs with 12 bit resolution with a Microchip MCP4822 dual channel 12‐bit DAC with internal voltage reference. Power to the board is provided through the host Raspberry Pi using the GPIO port. Only one ADC‐DAC Pi Zero can be used on a Raspberry Pi but the extended pins on the GPIO connector allow you to stack the ADC‐DAC Pi Zero along with other expansion boards. Mounting holes on the board can be used to securely fit the board on your Raspberry Pi. As the ADC‐DAC Pi Zero uses the same footprint as the Raspberry Pi Zero only two of the mounting holes can be used on the larger Raspberry Pi models. The A/D and D/A converters communicate with the Raspberry Pi through the SPI interface. Max ADC Sample Rate: 100,000 samples per second Max ADC Sample Rate under Python on a Pi 2: 12,000 samples per second                                             https://uk.pi‐supply.com/products/adc‐dac‐pi‐zero/3‐20‐19
PIS-1350
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离型光电开关。
2. 器件简介:EL817光电开关由一个红外发光二极管和一个光敏三极管组成,用于检测物体的有无。
3. 引脚分配:EL817有3个引脚,分别为Vcc、Out和GND。
4. 参数特性:工作电压为5V,检测距离为2-15mm,响应时间为1ms。
5. 功能详解:EL817通过检测物体对红外光束的遮挡来实现开关控制。
6. 应用信息:广泛应用于工业自动化、机器人等领域。
7. 封装信息:EL817采用DIP封装,便于焊接和安装。
PIS-1350 价格&库存
很抱歉,暂时无法提供与“PIS-1350”相匹配的价格&库存,您可以联系我们找货
PIS-1350
  • 1+214.631791+27.82037
库存:6
