ADC Differential Pi
Features
8 x 18‐bit differential inputs
Control via the Raspberry Pi I2C port
Stack up to 4 ADC Differential Pi boards on a single Raspberry Pi
Jumper selectable I2C addresses
Buffered 5V I2C port
Based on the MCP3424 from Microchip Technologies Inc
Input range of ±2.048V
On‐board 2.048V reference voltage (Accuracy ± 0.05%, Drift: 15 ppm/°C)
On‐Board Programmable Gain Amplifier (PGA): Gains of 1, 2, 4 or 8
Programmable Data Rate Options:
o
3.75 SPS (18 bits)
o
15 SPS (16 bits)
o
60 SPS (14 bits)
o
240 SPS (12 bits)
One‐Shot or Continuous Conversion Options
The ADC Differential Pi is an 8 channel 18 bit analogue to digital converter designed
to work with the Raspberry Pi. The ADC Differential Pi is based on two Microchip
MCP3424 A/D converters each containing 4 analogue inputs. The MCP3424 is a
delta‐sigma A/D converter with low noise differential inputs.
We designed the ADC Differential Pi as a companion for our ADC Pi. Unlike the ADC
Pi the ADC Differential Pi does not include any voltage dividers so the inputs can be
used to measure a differential
voltage range of ±2.048V. This is useful for measuring inputs below ±2.048V or
allows you to use your own voltage divider to measure higher voltages.
The ADC Differential Pi is powered through the host Raspberry Pi using the GPIO
port and extended pins on the GPIO connector allow you to stack the ADC
Differential Pi along with other expansion boards.
The two MCP3424 A/D converters communicate via i2c to the host Raspberry Pi
giving you eight analogue inputs to use. A logic level converter is included on the
ADC Pi Plus board giving you a buffered 5V i2c port making it easy to add other I2C
devices which operate at 5 volts without damaging the raspberry pi 3.3 volt i2c port.
The i2c buffer uses N‐channel mosfets with a maximum drain current of 100mA.
The I2C address bits are selectable using the on‐board jumpers. The MCP3424
supports up to 8 different I2C addresses so with two A/D converters on each ADC
Differential Pi you can stack up to 4 ADC Differential Pi boards on a single Raspberry
Pi giving you 32 ADC inputs.
The MCP3424 contains an on‐board 2.048V reference voltage with an input range of
±2.048V differentially (full scale range of 4.096V/PGA). A programmable Gain
Amplifier gives the user a selectable gain of x1, x2, x4 or x8 before the analogue to
digital conversion takes place.
The data rate for analogue to digital conversions is 3.75 (18 bit), 15 (16 bit), 60 (14
bit) or 240 (12 bit) samples per second. Data rate and resolution can be configured
within software using the I2C interface.
https://uk.pi‐supply.com/products/adc‐differential‐pi/3‐20‐19
很抱歉,暂时无法提供与“PIS-1351”相匹配的价格&库存,您可以联系我们找货
