ADC Pi
Features
8 x 17‐bit 0 to 5V Single Ended Inputs
Control via the Raspberry Pi I2C port
Stack up to 4 ADC Pi boards on a single Raspberry Pi
Jumper selectable I2C addresses
Buffered 5V I2C port
Based on the MCP3424 from Microchip Technologies Inc
Single Ended full‐scale range of 5.0V
On‐board 2.048V reference voltage (Accuracy ± 0.05%, Drift: 15 ppm/°C)
On‐Board Programmable Gain Amplifier (PGA): Gains of 1, 2, 4 or 8
Programmable Data Rate Options:
3.75 SPS (17 bits)
15 SPS (15 bits)
60 SPS (13 bits)
240 SPS (11 bits)
One-Shot or Continuous Conversion Options
The ADC Pi is an 8 channel 17 bit analogue to digital converter designed to work
with the Raspberry Pi. The ADC Pi is based on two Microchip MCP3424 A/D
converters each containing 4 analogue inputs. The MCP3424 is a delta‐sigma A/D
converter with low noise differential inputs.
We designed the ADC Pi to work as a single ended A/D converter using the
internal 2.048V reference voltage with the ‐V pins tied to ground. A voltage divider
on the ADC Pi board brings the input voltage range to a much more useful 0 – 5.06V.
In this configuration the sample size is 17 bits for each channel.
The ADC Pi is powered through the host Raspberry Pi using the GPIO port and
extended pins on the GPIO connector allow you to stack the ADC Pi along with other
expansion boards. The two MCP3424 A/D converters communicate via i2c to the
host Raspberry Pi giving you eight analogue inputs to use. A logic level converter is
included on the ADC Pi board giving you a buffered 5V i2c port making it easy to add
other I2C devices which operate at 5 volts without damaging the raspberry pi 3.3
volt i2c port. The i2c buffer uses N‐channel mosfets with a maximum drain current
of 100mA.
The I2C address bits are selectable using the on‐board jumpers. The MCP3424
supports up to 8 different I2C addresses so with two A/D converters on each ADC Pi
you can stack up to 4 ADC Pi boards on a single Raspberry Pi giving you 32 ADC
inputs.
The MCP3424 contains a programmable Gain Amplifier giving the user a selectable
gain of x1, x2, x4 or x8 before the analogue to digital conversion takes place.
The data rate for analogue to digital conversions is 3.75 (17 bit), 15 (15 bit), 60 (13
bit) or 240 (11 bit) samples per second. Data rate and resolution can be configured
within software using the I2C interface.
https://uk.pi‐supply.com/products/adc‐pi/3‐20‐19
很抱歉,暂时无法提供与“PIS-1352”相匹配的价格&库存,您可以联系我们找货
