PIS-0837
PIS-0837
    PISUPPLY
    ASUS TINKERBOARD S
PIS-0837 数据手册
    ASUS Tinker Board S With the Tinker‐Board S, ASUS introduces the successor of the legendary Tinker Board. The new and improved Tinker Board S is a single board computer (SBC) that offers greater durability, better stability and an overall improved user experience for DIY enthusiasts and makers everywhere. With its powerful and modern quad‐core ARM‐based processor — the Rockchip RK3288 — Tinker Board S offers significantly improved performance versus other popular SBC boards. To provide the flexibility needed for different builds and projects, Tinker Board S features 2GB of LPDDR3 dual‐channel memory and is equipped with an onboard 16GB eMMC and SD 3.0 interface that offer significantly faster read and write speeds for the OS, applications and file storage. Featuring a powerful but energy‐efficient design, Tinker Board S supports next‐generation graphics and GPU computing API's. Powered by an ARM‐based Mali™‐T760 MP4 GPU, Tinker Board S' GPU and fixed‐function processors allow for a wide range of uses, including high‐quality media playback, gaming, computer vision, gesture recognition, image stabilization and processing, as well as computational photography and more. Tinker Board S has HDMI CEC hardware circuit implemented, with the supported software, it allowing multimedia enthusiasts to control TV outputs using a single remote control for a better entertainment experience. Other fixed functions include H.264 and H.265 playback support, as well as HD and UHD video playback. Tinker Board S also features Gbit LAN for Internet and network connectivity. A dedicated bus resource designed for the LAN port ensures consistent Ethernet performance. The integrated Wi‐Fi and Bluetooth controller on the Tinker Board S is shielded with a metal cover to ensure minimal interference and improved radio performance. An integrated IPEX antenna header allows for easy antenna replacement or upgrades. More Durable  Onboard 16GB eMMC storage to enhance performance and stability, plus a microSD slot for greater flexibility  Low‐voltage input detection to avoid power issue and ensure system stability if using a non‐qualified* power supply Better User Experience  HDMI‐CEC‐ready for complete video entertainment, allowing users to command both Tinker Board S and a TV with a single remote control  Audio jack plug‐in detection and auto‐switch to 3.5mm audio jack from other interfaces Always Moving Forward with Makers  Onboard power‐on pin for makers giving more freedom when bringing their ideas to life  Enhanced I2S pin with Slave mode and an improved software API for better compatibility Technical info  Chipset: ARM Cortex‐A17 32‐bit Quad  CPU Clock: 180MHz  RAM: 2048mb  Memory: 16 (max. 64) GB  LAN: 10/100/1000  HDMI: Yes  SATA: No  USB: 4  Interfaces: LVDS, S/PDIF  Audio: Yes  Microphone Port: No  I/O: 40  SPI: Yes  I2C: Yes  UART: Yes  Bluetooth: 4.0  SD‐Slot: No  microSD‐Slot: Yes  CSI: Yes  DSI: Yes  Operating Voltage: 5 V  Low‐voltage connection: Micro USB Type B  Low‐voltage input: 5 V DC Note: All Raspberry Pi B +, 2 & 3 cases can also be used with the Asus Tinker S!                                https://uk.pi‐supply.com/products/asus‐tinker‐board‐s 10‐25‐18
PIS-0837 价格&库存
很抱歉,暂时无法提供与“PIS-0837”相匹配的价格&库存,您可以联系我们找货
