Denarius StakeBox
StakeBox and?Denarius?have partnered together to bring?you
the?DenariusStakeBox ‐ a?device that allows you to stake
your?Denarius cryptocurrency and make a return on your investment.?
Denarius is a Proof‐of‐Stake cryptocurrency which means you don't require a
powerful computer rig to earn rewards. Staking?is the process of securing the
network with your coin weight, which in turn rewards you with new Denarius.
The stakebox?requires little setup allowing you to get up and running in no time at
all and includes all the essential?accessories. Set it up and start earning crypto
rewards* without needing to buy an expensive?computer rig.?
What is Denarius?
Denarius is a new cryptocurrency based off the original Bitcoin Core by Satoshi
Nakamoto. Denarius features many changes, such as Stealth Addresses, Encrypted
Messaging, Tribus a new PoW hashing algorithm that is ASIC resistant, and a max of
10,000,000 DNR to be created during the hybrid PoW/PoS lifecycle of 3 years, which
then transitions to Proof of Stake entirely after the first 3 years.
What's Inside
Raspberry Pi 3 Model B
Denarius Case
2.5A International Power Supply Unit
16GB SD card with?Denarius software
HDMI cable
Raspberry Pi 3 Specifications
Processor
o
Broadcom BCM2387 chipset
o
1.2GHz Quad‐Core ARM Cortex‐A53
o
o
o
o
o
o
o
802.11 b/g/n Wireless LAN and Bluetooth 4.1 (Bluetooth Classic and LE)
GPU
Dual Core VideoCore IV? Multimedia Co‐Processor. Provides Open GL ES 2.0,
hardware‐accelerated OpenVG, and 1080p30 H.264 high‐profile?decode
Capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and?DMA
infrastructure
Memory
1GB LPDDR2
Operating System
Boots from Micro SD card, running a version of the Linux operating system
or?Windows 10 IoT
Dimensions
85 x 56 x 17mm
Power
Micro USB socket 5V1, 2.5A
Learn More
For more information on the?Denarius cryptocurrency, please
visit:?https://denarius.io/
*staking interest depends on the specific cryptocurrency and other conditions and is
not guaranteed by StakeBox
https://uk.pi‐supply.com/products/denarius‐stakebox 6‐26‐18
很抱歉,暂时无法提供与“PIS-0654”相匹配的价格&库存,您可以联系我们找货
