PIS-0159
PIS-0159
    PISUPPLY
    ENERGENIE PI-MOTE CONTROL STARTE
PIS-0159 数据手册
       Energenie Pi‐mote Control Starter Kit with 2 Sockets Plug Type UK  Energenie have developed the Pi‐mote control board to offer users of Raspberry Pi a low cost home control and automation solution. The Pi‐mote control is an add on board that permits control of 433mHz radio controlled electrical sockets. Easy to install and command, the product provides a simple and safe way to add control of mains powered devices and appliances to your Raspberry Pi. The best‐selling Energenie remote control sockets are now available with a controller board for your Raspberry Pi. Whether you are a Raspberry Pi newcomer, hacker, or Python sage you will be able to control your electrical sockets within a range of up to 30 metres, through doors, walls and ceilings. There is also some Python code, which enables simple on‐off control of the sockets, to get you going out of the box. This product is a Pi‐mote starter pack which contains the control board and two 13 Amp electrical sockets for use in standard UK 3‐pin mains sockets. We also have an option for EU plugs as well [Schuko format, check before ordering]! We also stock the control board by itself as well as a kit with a 4‐way extension lead. Energenie make a range of other compatible sockets which can also be operated by Pi‐mote control. If you already own Energenie sockets, these are backwards compatible with Pi‐mote Control. Technical Information   Transmitter Frequency: 433.92Mhz (ISIM band)  Output Power: 3 V / +12 dBm/27 mA  Range in open area: Up to 30 metres  Encoding: 20 address bits (pre‐set OTP), 4 data bits  Modulation: OOK/FSK software selectable The Energenie Pi‐mote control board is compatible with all of the Raspberry Pi Models ‐ A, A+, B, B+ and 2B. RESOURCES User Guide Further Product Information Python Code Raspberry Pi Blog ‐ Energenie Post Energenie Pi‐mote Python Module               https://uk.pi‐supply.com/products/energenie‐pi‐mote‐control‐starter‐kit‐2‐sockets 6‐27‐18
PIS-0159 价格&库存
很抱歉,暂时无法提供与“PIS-0159”相匹配的价格&库存,您可以联系我们找货
