PIS-0555
PIS-0555
    PISUPPLY
    箱 塑料 - 未指定 橙色,白色 手持式 2.835" 长 x 1.339" 宽(72.00mm x 34.00mm) X 1.063"(27.00mm)
PIS-0555 数据手册
Flick Zero Case SKU: PIS-0555 No Watch Strap SKU: PIS-0582 Black Watch Strap SKU: PIS-0581 White Watch Strap Spice up your Flick Zero and Raspberry Pi Zero with a stylish white and orange Flick Zero case! This vibrant and durable case is made up of three parts; an orange base and a white two piece lid. Flick can work through materials such as acrylic, wood and glass so our plastic case (even when the lid is in the closed position) will not negatively impact any of the fun you can have with Flick! Description Spice up your Flick Zero and Raspberry Pi Zero with a stylish white and orange Flick Zero case! This vibrant and durable case is made up of three parts; an orange base and a white two piece lid. This lid can be used in two different setups in either an open or closed position, allowing you to hide your Pi Zero and Flick Zero, or keep it visible to the world. Flick can work through materials such as acrylic, wood, and glass so our plastic case (even when the lid is in the closed position) will not negatively impact any of the fun you can have with Flick Suction cups The Flick Zero case features two knockout holes on the lid panels which can be pushed out with a pen. Two suction cups come as standard and can be installed in the knockout holes. The suction cups can be mounted on many different surfaces such as glass, plastic, or wood and still be removed easily. Perhaps you want to set up your Flick Zero & Raspberry Pi Zero to only allow entry through a door if you swipe the right pattern – with this case, you could mount it right next to the door without the need to drill any holes or hammer any nails. Features: • • • • 2 x suction cups 1 x orange base 2 x lid pieces Dimensions: 7.2cm x 3.4cm x 2.7cm Flick Software Visit our Flick GitHub page and acquire all the software you need to get up and running with your brand new Flick Zero and case. Additional information WEIGHT 0.065 kg DIMENSIONS 7.2 x 3.4 x 2.7 cm SELECT No Watch Strap, Black Watch Strap, White Watch Strap https://www.pi-supply.com/product/flick-zero-case/1-30-18
PIS-0555 价格&库存
很抱歉,暂时无法提供与“PIS-0555”相匹配的价格&库存,您可以联系我们找货
