JBM-005
JBM-005
    PISUPPLY
    DA101JC,WM8804GEDS 音频接口 音频 Raspberry Pi 平台评估扩展板
JBM-005 数据手册
  JustBoom Digi Zero pHAT SKU: JBM-005  The JustBoom Digi Zero pHAT is a high resolution digital audio output add on board for the Raspberry Pi Zero. The HAT produces a high quality audio data stream that will not be negatively affected in any way. We’ve designed the JustBoom Digi pHAT to be simple to install and use. With no soldering required and all the mounting hardware already provided you can be up and running in moments. We also include an optional IR receiver to allow remote control operation of your Raspberry Pi. It is also powered directly from the GPIO header so no extra cables or power supplies are required to connect to the Raspberry Pi. Description The JustBoom Pi Zero Digi pHAT is a high-resolution digital audio output add-on board for the Raspberry Pi Zero. The HAT produces a high-quality audio data stream that will not be negatively affected in any way. We’ve designed the JustBoom Digi pHAT to be simple to install and use. With no soldering required and all the mounting hardware already provided you can be up and running in moments. We also include an optional IR receiver to allow remote control operation of your Raspberry Pi. It is also powered directly from the GPIO header so no extra cables or power supplies are required to connect to the Raspberry Pi. Need help understanding how this product works? Follow our product guide. Setup Guide   Follow our full setup guide for assembling your JustBoom Digi Zero and Case. Configure the JustBoom Player software. Use cases   Streaming high-definition audio player Multi-room audio player Features           Our JustBoom Pi Zero Digi features full high-quality audio – 384kHz / 32bit Includes both a DAC and headphone amplifier Line-level RCA and headphone amplifier 3.5mm jack outputs Plug and play compatibility for ease of use No soldering required Powered by the Raspberry Pi GPIO header Compatible with Raspberry Pi Zero and the new Pi Zero Wireless Mounting hardware included Optional IR receiver included in package Full driver support in Raspbian / NOOBS   Technical Information        Dedicated S/PDIF interface chip supports up to 384kHz / 32bit resolution Cirrus Logic WM8804GEDS S/PDIF Transceiver Murata Power Solutions DA101JC Audio Digital Transformer Fully integrated hardware volume mixing via “alsamixer” or any ALSA compatible application Optional Vishay TSOP4838 IR receiver (solder yourself if required) 112db SNR and -93db THD for best-in-class audio Advanced ESD protection on both headphone and RCA outputs Description The JustBoom Pi Zero Digi pHAT is a high-resolution digital audio output add-on board for the Raspberry Pi Zero. The HAT produces a high-quality audio data stream that will not be negatively affected in any way. We’ve designed the JustBoom Digi pHAT to be simple to install and use. With no soldering required and all the mounting hardware already provided you can be up and running in moments. We also include an optional IR receiver to allow remote control operation of your Raspberry Pi. It is also powered directly from the GPIO header so no extra cables or power supplies are required to connect to the Raspberry Pi. Need help understanding how this product works? Follow our product guide. Setup Guide   Follow our full setup guide for assembling your JustBoom Digi Zero and Case. Configure the JustBoom Player software. Use cases   Streaming high-definition audio player Multi-room audio player     Features           Our JustBoom Pi Zero Digi features full high-quality audio – 384kHz / 32bit Includes both a DAC and headphone amplifier Line-level RCA and headphone amplifier 3.5mm jack outputs Plug and play compatibility for ease of use No soldering required Powered by the Raspberry Pi GPIO header Compatible with Raspberry Pi Zero and the new Pi Zero Wireless Mounting hardware included Optional IR receiver included in package Full driver support in Raspbian / NOOBS Technical Information        Dedicated S/PDIF interface chip supports up to 384kHz / 32bit resolution Cirrus Logic WM8804GEDS S/PDIF Transceiver Murata Power Solutions DA101JC Audio Digital Transformer Fully integrated hardware volume mixing via “alsamixer” or any ALSA compatible application Optional Vishay TSOP4838 IR receiver (solder yourself if required) 112db SNR and -93db THD for best-in-class audio Advanced ESD protection on both headphone and RCA outputs                             https://www.pi‐supply.com/product/justboom‐digi‐zero‐phat/ 1‐22‐18
JBM-005 价格&库存
很抱歉,暂时无法提供与“JBM-005”相匹配的价格&库存,您可以联系我们找货
