JBM-024
JBM-024
    PISUPPLY
    箱 红色 分叉式双侧 3.504" 长 x 2.441" 宽(89.00mm x 62.00mm) X 1.575"(40.00mm)
JBM-024 数据手册
JustBoom DAC HAT Case Black SKU: JBM-009 Red SKU: JBM-024 The DAC HAT Case is a stylish and durable enclosure for the Raspberry Pi and JustBoom DAC HAT ,with or without the Amp stacked on top. Removing or installing the Raspberry Pi, DAC or Amp board is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom DAC HAT and Amp. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! Description The DAC HAT Case is a stylish and durable enclosure for the Raspberry Pi and JustBoom DAC HAT ,with or without the Amp stacked on top. Removing or installing the Raspberry Pi, DAC or Amp board is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom DAC HAT and Amp. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! • • • • • • • • • DAC HAT Case Features: Supports and protects your JustBoom Amp, DAC HAT, and Raspberry Pi Easy to open case allows for quick access to your Amp, DAC or Raspberry Pi boards Smooth black finish that blends in with any audio setup Leaves all ports accessible Compatible with the Raspberry Pi 3, 2, and B+ No tools are needed for assembly or disassembly Designed and made in the UK from high quality material 4 x rubber feet included Access to micro SD port Setup Guide Follow our full setup guide for assembling your JustBoom DAC HAT and Case. WEIGHT 0.081 kg DIMENSIONS 8.9 x 6.2 x 4 cm https://www.pi-supply.com/product/justboom-dac-hat-case/2/8/18
JBM-024 价格&库存
很抱歉,暂时无法提供与“JBM-024”相匹配的价格&库存,您可以联系我们找货
