JBM-018
JBM-018
    PISUPPLY
    JUSTBOOM DAC HAT KIT
JBM-018 数据手册
      JustBoom DAC HAT Kit The JustBoom DAC HAT kit is a fully plug‐and‐play package that is simple to setup and use. No soldering or...    Description  The JustBoom DAC HAT kit is a fully plug‐and‐play package that is simple to setup and use. No soldering or technical knowledge is needed to get up and running. Plug in the power cable, connect the kit to a set of powered speakers or an audio amplifier, and set up the JustBoom Player software. You can then be up and running quickly, enjoying flawless high quality audio playback within minutes of unboxing. All of the Raspberry Pi GPIO pins are still accessible on the DAC HAT for easy customisation of your project ? add additional sensors, buttons, LEDs, rotary encoders or anything your heart desires.  Use Cases  Streaming (either from cloud or network storage) high‐definition audio player  Multi‐room audio player  Media centre / set‐top box living room entertainment system  Shop floor / elevator / background music audio player  High quality audio player with local storage  Desktop high definition audio player with amplified headphone output JustBoom DAC HAT Kit content  JustBoom DAC HAT  JustBoom DAC HAT Case  Raspberry Pi 3 Model B+  Official Raspberry Pi Power Supply  Pre‐loaded SD Card with JustBoom Player OS  RCA cable DAC HAT Features  Full high quality audio ? 384kHz / 32bit  Includes both a DAC and headphone amplifier  Line‐level RCA and headphone amplified 3.5mm jack outputs  Plug and play compatibility for ease of use  Hardware and software volume control from your Raspberry Pi  No soldering required  Powered by the Raspberry Pi GPIO header  This kit comes with a Raspberry Pi 3 Model B, however the DAC HAT is still compatible with the Raspberry Pi A+,B+ and 2B. It's also compatible with the Raspberry Pi Zero, but we would recommend the JustBoom DAC Zero for this purpose  Fully HAT compliant  Full driver support in Raspbian / NOOBS  Compatible with OSMC / Max2Play / RuneAudio / Volumio / Moode / PiCorePlayer / PiMusicBo x / OpenELEC and others                   https://uk.pi‐supply.com/products/justboom‐dac‐hat‐kit7‐31‐18
JBM-018 价格&库存
很抱歉,暂时无法提供与“JBM-018”相匹配的价格&库存,您可以联系我们找货
JBM-018
  • 50+1729.2883250+223.72961
