PIS-1588
PIS-1588
    PISUPPLY
    物理套件 micro:bit 初级入门套件
PIS-1588 数据手册
      Pi Supply micro:bit Tinker Kit (without micro:bit) Note: If you need a micro:bit, then we have the same kit that comes with a micro:bit. The Pi Supply micro:bit Tinker Kit is a set of micro:bit accessories that enables you to connect all kinds of modules easily to help you learn about coding and physical computing. The kit comes with ten different modules that are all designed to be controlled via the BBC micro:bit. We've developed 21 guides around this kit to help get you up and running as quickly as possible. Visit pisupp.lu/tinkerkit to view more. Kit contains  1 x Crystal Battery Box ‐ 2 x AAA  1 x Micro:bit Breakout Board  1 x Micro‐B USB Cable  1 x OLED Display  1 x Mini Servo  1 x Octopus PIR sensor Brick  1 x Octopus Soil Moisture Sensor Brick  1 x Octopus ADKeypad  1 x Octopus Crash Sensor Brick  1 x Octopus Passive buzzer Brick OBPB01  1 x Octopus 5mm LED Brick OBLED ‐ Red  1 x Octopus 5mm LED Brick ‐ Green  1 x Octopus 5mm LED Brick OBLED ‐ Blue  1 x Octopus Analog Rotation Brick OBARot       https://uk.pi‐supply.com/products/pi‐supply‐microbit‐tinker‐kit‐without‐microbit?_pos=1&_sid=db5e65791&_ss=r/7‐30‐19
PIS-1588 价格&库存
很抱歉,暂时无法提供与“PIS-1588”相匹配的价格&库存,您可以联系我们找货
PIS-1588
  • 1+635.477831+82.20876
库存:48
