Pi Supply micro:bit Starter Kit (without
micro:bit)
Note: If you need a micro:bit, then we have the same kit that comes with a
micro:bit.
The Pi Supply micro:bit Starter Kit is designed for people wishing to get into
electronics, programming and physical computing at the entry level. This kit
contains some basic parts like LEDs and buttons as well as a buzzer, temperature
sensor, servo, and motor. You can use it to design circuits and with the help of your
micro:bit programming skills you can make your circuit even more animated. It is a
great companion for you to enter into the wonderful world of physical computing.
We've developed guides around this kit to help get you up and running as quickly as
possible.
This kit comes with 13 projects that will teach you the essential principles of
electronics and basic programming, providing you with a great foundation to move
forward into more complicated STEM and computing projects.
Kit contains
1 x micro:bit Breadboard Adapter
1 x Transparent Breadboard ‐ 83 * 55 mm
1 x Crystal Battery Holder ‐ 2 x AAA
1 x EF92A micro:servo 180 degrees analog servo for micro:bit
1 x TMP36 Temperature Sensor
1 x Photocell
1 x MicroB USB Cable
1 x Breadboard Jumper Wire 65pcs Pack
1 x RGB Diffused LED
5 x Red LED
5 x Blue LE
5 x Yellow LED
5 x Green LED
1 x 10K Trimpot
2 x Momentary Pushbutton Switch
1 x Self‐lock Switch
1 x Mini Speaker
10 x 100 Ohm Resistors
10 x 10K Ohm Resistor
5 x Alligator Clip Wires
1 x 5V Miniature Motors
1 x TIP 120 NPN Transistor
2 x 1N4007 Diodes
1 x 8 RGB Rainbow LED Ring
Projects include
Make 2 LEDs blink in a pattern
Display data on the BBC micro:bit's LED panel
Use a switch to start/stop a motor
and many more!
https://uk.pi‐supply.com/products/pi‐supply‐microbit‐starter‐kit‐without‐microbit?_pos=1&_sid=f00df108f&_ss=r/8‐1‐19
很抱歉,暂时无法提供与“PIS-1589”相匹配的价格&库存,您可以联系我们找货
