PIS-1188
PIS-1188
    PISUPPLY
    箱 绿色 铰链门 6.496" 长 x 4.409" 宽(165.00mm x 112.00mm) X 3.071"(78.00mm)
PIS-1188 数据手册
    NatureBytes Wildlife Camera Case Our robust case will protect your electronics from the elements, it is compatible with all Raspberry Pi models, it has an IR Lens to optimise motion detection, a camera strap so you can set‐up your ideal wildlife shots or you can take advantage of the electronics mount, with space for additional sensors, power solutions and upgrades….and it looks awesome! The NatureBytes Wildlife Camera Case is the perfect weatherproof housing to take your Raspberry Pi and camera outdoors. Designed and made by tech and conservation experts in the UK. The robust weatherproof case will protect your electronics from the elements, it is compatible with all Raspberry Pi models, it has an IR Lens to optimise motion detection, a camera strap so you can set‐up your ideal wildlife shots or you can take advantage of the electronics mount, with space for additional sensors, power solutions and upgrades….and it looks awesome! Note: this is for the case only – no electronics included.  Weatherproof (certified IP55)  Electronics mount compatible with all models of Raspberry Pi (including model B and Zero models)  Fresnel IR lens to optimise motion detection  Clip and hinge opening for easy access to the Pi’s ports and internal components  Nylon camera attachment strap for securing outside  Can be secured with a padlock  Fasteners and spacers for attaching electronics  Rear cable access  Rear attachments for modular upgrades  No soldering required  Bill of materials for Cam kit can be found here https://cdn.shopify.com/s/files/1/2187/3161/files/Cam_Kit_BOM.pdf Dimensions  When closed: 16.5cm x 11.2cm x 7.8 cm https://uk.pi‐supply.com/products/naturebytes‐wildlife‐camera‐case?_pos=1&_sid=9547ef20f&_ss=r/7‐30‐19
PIS-1188 价格&库存
很抱歉,暂时无法提供与“PIS-1188”相匹配的价格&库存,您可以联系我们找货
