PIS-0908
PIS-0908
    PISUPPLY
    箱 分叉式双侧 X
PIS-0908 数据手册
        NESPi Case+ with Cooling Fan, Heatsinks and Flannel Bag This NESPI Raspberry Pi Case+ is an inspired enclosure for your Raspberry Pi system. It can turn your bare Raspberry Pi 2B/3B/3B+ into an elaborate console. It has the most iconic elements of the retro game world and even features a small hinged door with two USB ports and one standard RJ‐45 connector behind.  Description This NESPI+ case has the most iconic elements of the retro game world as a homage to the most classic console ever made. It has a small hinged door with two USB ports and one standard RJ‐45 connector behind. With improved HDMI and Audio ports, it enhances the experience of using your HDMI and audio output cables. You can insert your Micro SD card on the side to allow more space for you to operate more freely. Your Raspberry Pi PCB will fit perfectly so that you can use it like a NES console as how you remember it. Features  Safe Shutdown and Safe Reset (see here)  RetroPie software (download latest software)  This version has a safe shutdown switch added  Functional LED power indicator  Air ventilation can be installed inside the upper enclosure  Functional POWER and RESET buttons  NES Case that is specifically designed for Raspberry Pi 3B+/3B/2B  Easy access to the SD Card and all other ports. You do not need to open the case. Includes  NESPi Case  2 x USB power cable  Internet cable, fan power cord, USB cable  Adaptable PCB x 4  Screw driver x 1  Instruction manual x 1  Cooling Fan x 1  3 pcs of Heatsinks Set x1  Flannel bag for NESPi Case x1        https://uk.pi‐supply.com/products/nespi‐case 8‐27‐18
PIS-0908 价格&库存
很抱歉,暂时无法提供与“PIS-0908”相匹配的价格&库存,您可以联系我们找货
