PIS-1138
PIS-1138
    PISUPPLY
    IMX219 照相机 传感器 Raspberry Pi 平台评估扩展板
PIS-1138 数据手册
          Night vision camera module for Raspberry Pi ‐ 160° (Fisheye) Night vision camera module for Raspberry Pi Light up the night with this 160° fisheye lens night vision camera module with infra‐ red LEDs for Raspberry Pi! The IR LEDs allow the camera to see in the dark without producing any visible light. The camera has a 5MP sensor, a full‐sized cable connector and two camera cables so you can use it with either a Raspberry Pi Zero or a full‐sized Raspberry Pi such as the 3B+. It also comes with a lens cap to protect the camera when it's not being used. The infra‐red LEDs create roughly 1W of heat when in use, as they're pretty powerful to provide good illumination. Due to this, make sure there is enough ventilation around the camera and Raspberry Pi to keep them cool. Features  5MP sensor, 2592x1944 pixels  1080p video at 30 FPS (or 60 FPS at 720p, 90 FPS at 480p)  f2.4 lens, 1.85mm focal length 160° (wide‐angle) FOV  Includes 15cm Pi Zero camera cable, and 15cm standard camera cable  Lens cap  Dimensions: 72.60 x 24mm (including cable connector)  Variable focus   https://uk.pi‐supply.com/products/night‐vision‐camera‐module‐for‐raspberry‐pi‐160‐degree‐fisheye?_pos=1&_sid=f8ee745c1&_ss=r7‐30‐19
PIS-1138 价格&库存
很抱歉,暂时无法提供与“PIS-1138”相匹配的价格&库存,您可以联系我们找货
PIS-1138
  • 1+242.910931+31.42702
  • 5+222.475415+28.78314
  • 10+214.8658110+27.79863
库存:18
