Octopus 1 Channel Relay 3V Relay Module for
Micro:bit
The Pi Supply Octopus 1 Channel Relay 3V Relay Module has adopted a mini and
high-quality HUIKE relay which is able to control all kinds of home appliances and
high current load devices.
What are Octopus Electronic Bricks?
Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as
easy as piling bricks. You can also connect Arduino compatible boards easily with
various digital, analog and I2C/Uart interfaces. The breadboardless connections let
you connect expansion modules like potentiometers, sensors, relays, servos, buttons
in a plug and play way.
Features
Equipped with a high current relay. Its max current can be up to 2A.
Adopt 3V power supply, which is enough to support micro:bit.
Contact control including a normally open contact and a normally closed contact.
Convenient wire connection
https://uk.pi‐supply.com/products/1‐channel‐relay‐3v‐relay‐module‐for‐microbit?_pos=1&_sid=44625e4b7&_ss=r/2‐17‐20
很抱歉,暂时无法提供与“PIS-1267”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+61.870701+8.01190
