Octopus 5mm LED Brick ‐ Green
The Pi Supply Octopus 5mm LED light brick (ambient light
sensor) extension can be connected to Arduino boards. The
digital pin (LOW on, HIGH off) is used to control it. The
brightness of LED can be controlled via PWM output.
There are five colors for you to choose from
White
Red
Blue
Green
Yellow
What are Octopus Electronic Bricks?
Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as
easy as piling bricks. You can also connect Arduino compatible boards easily with
various digital, analog and I2C/Uart interfaces. The breadboardless connections let
you connect expansion modules like potentiometers, sensors, relays, servos, buttons
in a plug and play way.
Specifications
Voltage: +3.3‐5V
Pin Definition :1 Signal(Yellow) 2 Vcc(Red) 3 GND(black)
Weight: 5g
What’s Included
1 x 5mm LED Brick
1 x Analog Sensor Cable
https://uk.pi‐supply.com/products/octopus‐5mm‐led‐brick‐green?_pos=1&_sid=5a355dc1b&_ss=r/7‐30‐19
很抱歉,暂时无法提供与“PIS-1279”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 280+25.40052280+3.28595
