PIS-1280
PIS-1280
    PISUPPLY
    蓝光 LED Opto Octopus 平台评估扩展板
PIS-1280 数据手册
      Octopus 5mm LED Brick OBLED ‐ Blue The Pi Supply Octopus 5mm LED light brick (ambient light sensor) extension can be connected to Arduino boards. The digital pin (LOW on, HIGH off) is used to control it. The brightness of LED can be controlled via PWM output. There are five colors for you to choose from  White  Red  Blue  Green  Yellow What are Octopus Electronic Bricks?   Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as easy as piling bricks. You can also connect Arduino compatible boards easily with various digital, analog and I2C/Uart interfaces. The breadboardless connections let you connect expansion modules like potentiometers, sensors, relays, servos, buttons in a plug and play way. Specifications  Voltage: +3.3‐5V  Pin Definition :1 Signal(Yellow) 2 Vcc(Red) 3 GND(black)  Weight: 5g What’s Included  1 x 5mm LED Brick  1 x Analog Sensor Cable https://uk.pi‐supply.com/products/octopus‐5mm‐led‐brick‐obled‐blue?_pos=1&_sid=a9797d125&_ss=r/7‐30‐19
PIS-1280 价格&库存
很抱歉,暂时无法提供与“PIS-1280”相匹配的价格&库存,您可以联系我们找货
