Octopus Analog Rotation Brick ‐ Blue
The Pi Supply Octopus analog rotation brick is a 10K potentiometer module.
Rotating the knob to change its resistance can realize voltage division while
providing analog signals to the analog input IO ports of microcontroller. This
module has a 3‐wire anti‐reverse connector, which makes it easy to connect a GVS
cable.
What are Octopus Electronic Bricks?
Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as
easy as piling bricks. You can also connect Arduino compatible boards easily with
various digital, analog and I2C/Uart interfaces. The breadboardless connections let
you connect expansion modules like potentiometers, sensors, relays, servos, buttons
in a plug and play way.
Features
Integrated 3‐wire anti‐reverse connector.
Rotate the knob to adjust resistance without using a screwdriver.
Compact structure.
What’s Included
1 x Octopus Analog Rotation Brick‐Blue
1 x 3‐pin Cable
https://uk.pi‐supply.com/products/octopus‐analog‐rotation‐brick‐blue?_pos=1&_sid=18b2dcd38&_ss=r8‐1‐19
很抱歉,暂时无法提供与“PIS-1266”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 262+25.40050262+3.28595
