PIS-1281
PIS-1281
    PISUPPLY
    旋转电位计 人机接口 Octopus 平台评估扩展板
PIS-1281 数据手册
    Octopus Analog Rotation Brick OBARot The Pi Supply Octopus Analog Rotation Brick is Arduino compatible and can be rotated up to 300 degrees. It is based on a potentiometer. In combination with an Arduino IO expansion board it can be very easy to achieve position‐dependent interaction with the rotating effect or produce MIDI instrument. What are Octopus Electronic Bricks? Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as easy as piling bricks. You can also connect Arduino compatible boards easily with various digital, analog and I2C/Uart interfaces. The breadboardless connections let you connect expansion modules like potentiometers, sensors, relays, servos, buttons in a plug and play way. What’s Included  1 x Analog Rotation Brick  1 x Analog Sensor Cable Specification  Power supply needs: 5V  Interface type: Analog  Pin Definition: S‐Sigal V‐VCC G‐GND  Wide detecting scope  High sensitivity  300 degree rotation sensor  Size: 19x27mm https://uk.pi‐supply.com/products/octopus‐analog‐rotation‐brick‐obarot?_pos=1&_sid=ecc86e417&_ss=r/8‐1‐19
PIS-1281 价格&库存
很抱歉,暂时无法提供与“PIS-1281”相匹配的价格&库存,您可以联系我们找货
