Octopus BME280 Pressure Sensor
The Pi Supply Octopus BME280 Pressure Sensor is an electric brick which has
integrated temperature sensor, air pressure sensor, and humidity sensor onboard. It
can be used to measure humidity, temperature, and air pressure, or even to
calculate the altitude according to the measured air pressure.
What are Octopus Electronic Bricks?
Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as
easy as piling bricks. You can also connect Arduino compatible boards easily with
various digital, analog and I2C/Uart interfaces. The breadboardless connections let
you connect expansion modules like potentiometers, sensors, relays, servos, buttons
in a plug and play way.
Features
Low power consumption
Small size
3mm standard positioning hole.
Rated 3.3v power supply, which is enough to support micro:bit.
Support I2C and SPI protocol.
https://uk.pi‐supply.com/products/octopus‐bme280‐pressure‐sensor?_pos=1&_sid=f0e6b5cd5&_ss=r/8‐1‐19
很抱歉,暂时无法提供与“PIS-1273”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+127.212121+16.45683
