Octopus Crash Sensor Brick
The Pi Supply Octopus Crash Sensor Brick is a sensor module based on a crash
switch with high sensitivity.
What are Octopus Electronic Bricks?
Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as
easy as piling bricks. You can also connect Arduino compatible boards easily with
various digital, analog and I2C/Uart interfaces. The breadboardless connections let
you connect expansion modules like potentiometers, sensors, relays, servos, buttons
in a plug and play way.
Specifications
Arduino special module
Compatible with sensor shield
Output low level when touched, maintain high level when released
Used for robot collision detection touch detection
3P buckled wires connector
Easy to plug and play
Able to achieve very interesting and an interactive work
https://uk.pi‐supply.com/products/octopus‐crash‐sensor‐brick?_pos=1&_sid=99d1a1e16&_ss=r/8‐1‐19
很抱歉,暂时无法提供与“PIS-1283”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 280+25.39828280+3.28595
