Octopus Hunt Sensor
The Pi Supply Octopus Hunt Sensor is a sensor based on TCRT5000 photoelectric
sensitive element. It can detect the infrared reflected signal. Together with an
Arduino specific sensor shield the Hunt Sensor can be widely used in many fields
ranging from
Black and white line detection
Obstacle detection
Shredding detection for fax machine or paper shredder
Meter pulse data sampling
And much more
Adjustable sensitivity (shown in blue digital potentiometer adjustment). Three pins
electronic building blocks interface: input 5V ‐ GND. S pin output digital voltage
signal 0‐1 Operating voltage: DC 5.0V
What are Octopus Electronic Bricks?
Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as
easy as piling bricks. You can also connect Arduino compatible boards easily with
various digital, analog and I2C/Uart interfaces. The breadboardless connections let
you connect expansion modules like potentiometers, sensors, relays, servos, buttons
in a plug and play way.
Parameter
Power supply needs: 5V
Interface type: Analog
Pin Definition: 1‐Signal 2‐VCC 3‐GND
Fast response and High sensitivity
Simple drive circuit
Stable and long life
Features
Use TCRT5000 photoelectric conversion element, with a built‐in infrared emitting
tube and a receiving tube
Operating current for emitting tube and receiving tube was respectively 10mA,
0.1mA
Indicator: an electric signal indicator. (Find a black line, it will be on)
PCB positioning hole: 3.2mm standard positioning holes, capable of installing
3.2mm standard studs, screws.
What’s Included
1 x Octopus Hunt Sensor
1 x Analog Sensor Cable
https://uk.pi‐supply.com/products/octopus‐hunt‐sensor?_pos=1&_sid=1e47453f2&_ss=r/8‐1‐19
很抱歉,暂时无法提供与“PIS-1268”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+39.068851+5.05460
