PIS-1278
PIS-1278
    PISUPPLY
    蜂鸣器 音频 Octopus 平台评估扩展板
PIS-1278 数据手册
    Octopus Passive buzzer Brick OBPB01 The Pi Supply Octopus passive buzzer brick is a buzzer module whereby the volume can be controlled by PWM. What are Octopus Electronic Bricks?   Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as easy as piling bricks. You can also connect Arduino compatible boards easily with various digital, analog and I2C/Uart interfaces. The breadboardless connections let you connect expansion modules like potentiometers, sensors, relays, servos, buttons in a plug and play way. What’s Included  1 x Passive buzzer Brick  1 x Analog Sensor Cable Specification  Power supply needs: 5V  Interface type: Analog  Pin Definition: S‐Sigal V‐VCC G‐GND  Wide detecting scope  High sensitivity  Simple drive circuit  Stable and long life  Size: 19x27mm https://uk.pi‐supply.com/products/octopus‐passive‐buzzer‐brick‐obpb01?_pos=1&_sid=394688795&_ss=r/8‐1‐19
PIS-1278 价格&库存
很抱歉,暂时无法提供与“PIS-1278”相匹配的价格&库存,您可以联系我们找货
