Octopus Rain/Steam Sensor
The Pi Supply Octopus Rain/Steam Sensor can be connected to the Arduino IO
Expansion shield directly. The output voltage will increase when the humidity of the
sensor surface goes up. You can even use it as a touch panel.
What are Octopus Electronic Bricks?
Pi Supply Octopus Electronic Bricks can be used to build electronics projects just as
easy as piling bricks. You can also connect Arduino compatible boards easily with
various digital, analog and I2C/Uart interfaces. The breadboardless connections let
you connect expansion modules like potentiometers, sensors, relays, servos, buttons
in a plug and play way.
Warning: The connector is not waterproof. Please be careful not to put the
connector directly in water.
What’s Included
1 x Octopus Rain/Steam Sensor
1 x Analog Sensor Cable
Parameter
Power supply: 3.3v or 5v
Output voltage signal: 0~4.5v or 0~3.0v
Pin definition:
Analog output(Yellow wire)
GND(Black wire)
Power(Red wire)
Applications
Simple rain detector
Cheap steam level switch
Touch sensor based on humidity
https://uk.pi‐supply.com/products/octopus‐rain‐steam‐sensor?_pos=1&_sid=6d0862fb9&_ss=r/7‐31‐19
很抱歉,暂时无法提供与“PIS-1271”相匹配的价格&库存,您可以联系我们找货
