Pi‐hole 16GB SD Card Image
Pi Hole Kit ‐ A Network Wide Ad Blocking device
Pi Supply and Pi Hole have partnered together to bring you a 16GB microSD Card
pre‐flashed with the Pi Hole software that you can plug straight into a Raspberry Pi
3 Model B and start blocking all of those annoying advertisements on the internet.
Since Pi‐hole works at the DNS level, ads can be blocked on any device and even in
apps.
*Please note: There is an issue with the Pi‐hole software on the Raspberry Pi 3
Model B+. This image is for the Raspberry Pi 3 Model B.
Block Over 100,000 Ad‐serving Domains
Known ad‐serving domains are pulled from third party sources and compiled into
one list.
Block Advertisements On Any Device
Network‐level blocking you to block ads in non‐traditional placed such as mobile
apps and smart TVs, regardless of hardware or OS.
Improve Overall Network Performance
Since ads are blocked before they are downloaded, your network will perform
better.
Reduce Cellular Data Usage
Pair your Pi‐hole with a VPN for on‐the‐go ad‐blocking and save on data costs.
Monitor Performance And Statistics
The Web interface shows how many ads were blocked, a query log, and more.
API
Utilize Pi‐hole’s API in your scripting or programming projects.
"domains_being_blocked":243038,
"dns_queries_today":2385,
"ads_blocked_today":414,
"ads_percentage_today":17.35849,
"unique_domains":429,
"queries_forwarded":1537,
"queries_cached":434,
"clients_ever_seen":5,
"unique_clients":5,
"status":"enabled"
Use Pi‐Hole As Your DNS Server
Configure your router’s DHCP options to force clients to use Pi‐hole as their DNS
server, or manually configure each device to use the Pi‐hole as their DNS server.
If your router doesn’t let you change these settings, you can use Pi‐hole’s built in
DHCP server to achieve the same effect.
Block Ads Everywhere
apps.
https://uk.pi‐supply.com/products/pi‐hole‐16gb‐sd‐card‐image 6‐26‐18
很抱歉,暂时无法提供与“PIS-0798”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+187.3898550+24.31368
